How to edit the amount of units per hour
Revision as of 09:55, 18 November 2026 by Server@tygron.com (talk | contribs)
The amount of units per hour can be edited and is used for displaying traffic overlays in the 3D Visualization.
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar) → The Building to edit (Left panel)
How to Edit the amount of units per hour for a Unit Type:
  1. Select Current Situation.
  2. Select Buildings on the ribbon bar.
  3. Select "Roads" in the left panel.
  4. Select the desired road (part) in the left panel
  5. Change the units per hour in the right panel
  6. Optionally change the Function of the road if it does not support your Unit Type.
  • Optionally change the Function of the road if it does not support your Unit Type.
