How to add an Attribute to a Function
Revision as of 09:53, 18 November 2026 by Server@tygron.com (talk | contribs)
While each Function in Tygron Platform has many Function Values, the defaults may not cover all building aspects needed for your calculations. It is possible to add user-defined Attributes to any Function, which behave very similarly to built in Function Values.
How to add an Attribute to a Function:
  1. Set the group filter to "Custom".
  2. At the bottom of the window, enter the name for the Attribute in the Attribute input field
  3. Click on "Add" next to the Attribute input field.
  4. The Attribute is now added to all Functions, and can be edited.
  • Selecting the group filter Custom hides the default function and category values of a function. The group filter Attributes shows both.
  • The Function selected in the Function Values window will have the added Attribute set to 1. Other Functions will have their value for that Attribute listed as 0.
API Endpoints
