Model attributes (Watershed Overlay)
Revision as of 15:48, 17 November 2026 by Frank@tygron.nl (talk | contribs)
The Watershed Overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the watershed overlay and can be modified as such.
Icon Attribute Unit Description
FILL_DISTANCE m Discharge areas expand to unassigned cells until the fill distance is reached or, if LIMIT_ROAD is enabled, a road cell is encountered.
DISCHARGE_REMAINING_WATER bool Create additional discharge areas for water terrains that are not connected by culverts to the general water system. Only water terrains that are larger then the configured minimal area can become independent discharge areas.
CULVERT_FLOW_DIRECTION bool Use culvert flow direction to limit the way discharge areas are propagated. When active and water flows from cell A to cell B through a culvert, the discharge area of B is propagated to cell A when it is not yet assigned to a prioritized discharge area.
MIN_AREA m2 The minimum area required for a water terrain to be considered an independent discharge area.
LIMIT_ROAD bool Whether the gradual expansion of calculated watershed to unassigned cells should stop at roads.
