Api session event editor geotiff
API Endpoint: api/session/event/editorgeotiff/
API Endpoints for GeoTIFF editing.
| Name | Description |
| add | Add a new GeoTIFF for a GeoTIFF file provided as an array of bytes. For files larger than 2GB, use the Stream API or Web URL |
| remove | Remove existing GeoTIFF |
Additional API Endpoints:
| add_ascii | Add new GeoTIFF for a provided ASCII file. For files larger than 2GB, use the Stream API or Web URL |
| add_ascii_url | Add new GeoTIFF Item from Web ASCII URL |
| add_url | Add a new GeoTIFF from a Web URL |
| export | Export a GeoTIFF as a byte array. For files larger than 2GB, use the Stream API |
| set_geotiff | Update existing GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL |
| set_geotiff_url | Update existing GeoTIFF Item from Web URL |
