Hover panel
Revision as of 09:48, 12 November 2026 by Frank@tygron.nl (talk | contribs)
The hover panel. When hovering over any location in the project map in the 3D Visualization, it appears to provide information about the area indicated.
When you hover over any part of the project map, the hover panel will appear. The hover panel will display information about the area your cursor is pointing at, based on which overlay is currently active. By default, it display information about the:
