Api session event editor parametric
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/
API Endpoints for Parametric editing.
Name Description
add Add a Parametric Design of a particular Alignment
append_attribute Appended to existing Parametric numeric Attribute value
duplicate Duplicate existing Parametric
remove Remove existing Parametric
remove_attribute Remove numeric Attribute from Parametric
set_attribute Set Parametric numeric Attribute value
set_attributes Set multiple Parametric numeric Attribute values
set_name Set the name of a Parametric Design
set_polygons Set Polygons to existing Parametric
Additional API Endpoints:
Name Description
add_example Add a Parametric Design using a particular example
add_plot Add a Plot Design of a particular Function to a Parametric Design
apply Apply a Parametric Design for a Stakeholder, Function Types, Function IDs and one or more MultiPolygons per Function Type
generate Generate a result for a Parametric Design
remove_plot Remove a Plot Design of a Parametric Design
remove_plot_attributes Remove Attributes from a Plot Design of a Parametric Design
save_as_measure Save a Parametric Design as a new Measure for a Stakeholder, using Function Types, Function IDs and one or more MultiPolygons per Function Type
set_alignment Set the alignment of a Parametric Design
set_function Set a Function of a Function Type for a Parametric Design. Use Function ID -1 to remove it for a Function Type
set_plot_attributes Set Attributes of a Plot Design of a Parametric Design
set_plot_function Set the Function of a Plot Design of a Parametric Design
