How to add a dynamic traffic model
A dynamic model changes (over time), according to changes made in the project. For example, a dynamic traffic model can calculate how traffic intensity changes as new houses are built. Effectively the TRAFFIC_FLOW attribute of the buildings will be updated with a new value, when building houses in the Tygron Platform.
To create such a model, first create a GeoJSON file with the roads that will be changed by a certain Action or Measure and import the file. Use an Excel file to calculate the timing and amount of traffic intensity changes. This file can be uploaded as either an indicator or panel. The description for the indicator or panel is not required for this model. The Excel is only used to define the model and import it in the Tygron Platform.
The Excel implementation of a simple dynamic traffic model, consists of the following consecutive steps:
- Retrieval of the original traffic density in Area X -
SELECT_ATTRIBUTE_WHERE_AREA_IS_X_AND_NAME_IS_TRAFFIC_FLOW
- Calculation in an excel file, with the new traffic density as outcome -
original traffic density + change
- Output of the new traffic density for constructions in Area X -
UPDATE_BUILDING_TRAFFIC_FLOW_WHERE_AREA_IS_X_AND_AREA_WITH_ATTRIBUTE_IS_TRAFFIC_FLOW
Import Areas
- Select the Geo Data header
- Select Geo Import in the ribbon bar
- Notice that a Geo Data Wizard window appears
- Select the type 'Areas' in the Geo Data Wizard
- Select the 'Import a GeoJSON file' option in step 1 of the wizard
- Select the GeoJSON file you wish to add in step 1
- View the features of the selected GeoJSON file in step 2
- Select the 'No Filtering' option in step 3
- Select 'Import a New Area with attributes' in step 4
- Select an option on how you want to name the features in step 5
- Ensure that the attribute TRAFFIC_FLOW is activated in the list of attributes in step 6
- Select 'Finish' in step 7
4. Select the type 'Areas'
5. Select the 'Import a GeoJson file' option
6. Select the GeoJson file you wish to add
7. View the features of the selected GeoJson file
8. Select the 'No filtering' option
9. Select 'Import a New Area with attributes'
10. Choose how you want to name the features
11. Select the TRAFFIC_FLOW attribute
12. Select 'Finish'
- Select the Indicators header
- Select the Indicators bar or Panels bar depending on what is needed
- Select the type 'Add Excel Indicator' option or 'Add Excel Panel' in the dropdown menu
- Select 'Select Excelsheet' in the right panel
- Select 'Import New Excelsheet' in the popup window
- Choose an excelsheet and select 'Apply'
- Rename the added indicator in the 'Name' and 'Short Name' fields on the right panel
- Select the color to be used in the progression panel
- Select to activate the indicator, if desired
- Add a proper description
- Highlight 'Excel File Name' on the left panel
- Select the 'Upload' button
- Select the file to upload in the 'Choose your file' panel
- Select Indicators > recalculate Indicators
