How to assign a Panel to a specific Stakeholder
Revision as of 11:09, 14 October 2026 by Frank@tygron.nl (talk | contribs)
Panels can be restricted so that only specific Stakeholders have access to them. This means that even if they have a geographical location in the project map, the Popup will only be shown to the Stakeholder which owns the Panel. This also means that even if another Stakeholder somehow opens the Panel, only a message will be displayed indicating that the Stakeholder does not have access to that Panel (instead of displaying the Panel's proper content).
Editor → Current Situation (Ribbon tab) → Panels (Ribbon bar) → The Panel to edit (Left panel)
How to assign a Panel to a specific Stakeholder:
  1. Open the list of Panels.
  2. Open the "Single Panels" listing.
  3. In the left panel, select the panel to edit.
  4. In the right panel, ensure "Assign to Stakeholder" is checked.
  5. In the right panel, set the Stakeholder dropdown to the Stakeholder which should have sole access to the Panel.
  6. The Panel is now assigned to a specific Stakeholder.
API Endpoints
