How to add and remove buildings
Revision as of 12:07, 7 October 2026 by Frank@tygron.nl (talk | contribs) (→Initial Building types to add)
This section deals with adding Buildings to the project. For adding actions to a Stakeholder see Adding and removing Actions.
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar)
Building panel
When a project is created in the Tygron Platform, Buildings are automatically added by Geo Plugins to initialize the current situation of your project. Buildings can also be added to or removed from the Current Situation of your project using the editor. To add or remove buildings to an existing project, start an editing session of your project and once loaded, select Current Situation in the ribbon bar and click on the Buildings button:
Adding buildings
Select a building type and click 'Add' at the bottom of the list to add a new building. The list is alphabetical per building type. The new building is not yet present in the project map, since it has not been placed. For details on adding / changing a selection from a building: see below.
How to add buildings:
  1. Select Current Situation
  2. Select Buildings on the ribbon bar
  3. Select the desired building type from the drop down list
  4. Select 'Add' from the bottom of the list
  5. Notice a new building has been added to the building list
In the Editor, there are initially three types of man made buildings available to add: standard buildings, roads and underground.
  • Standard Buildings. Standard buildings are generic structures located on the surface. Most standard buildings are specific for one or more regions in the world. Currently, the defined regions are Africa, Asia, North America and Europe. Standard buildings are adjustable: they can be adjusted according to the available space and desired amount of floors. Note that a standard building does not necessarily represent an individual unit. It can represent a group of houses, or multiple warehouses as well.
  • Roads. Roads are paved or improved thoroughfares used for travel. In the Tygron Platform, roads range from African dirt roads to high tech Asian Rapid Transit Rails.
  • Underground. Underground buildings include metro lines, culverts, cellars/ foundations, (dangerous materials) storage containers, parking garages and more.
Removing buildings
To completely remove a building, including its slot from the building list, select Buildings, highlight the building to be removed and select 'Remove'. This will open a confirmation message to ensure no buildings are deleted by accident.
How to remove buildings:
  1. Open the Building Panel
  2. Highlight the building to be removed
  3. Select "Remove" on the bottom of the list
  4. Confirm the deletion on the popped up message panel
Removing buildings with Measures
If removing buildings is part of a measure, use Flatten spatials of Measures to define regions for removal.
