How to edit building addresses
- With a building selected on the left panel, it is possible to edit its address on the bottom panel. In case a (newly added) building lacks an address, it is possible to select the 'Import' button. The address will then be assigned automatically to the selected building, if available. If no address is known due to the building's planning state, enter the desired address in the name field. By selecting the 'Add' button on the bottom panel, the address-as-name will be added to the building as an address property. It is also possible to duplicate or remove addresses from this list.
- How to add and remove buildings
- How to edit building properties
- How to draw selections for buildings
API Endpoints
- Api session event editor address add
- Api session event editor address duplicate
- Api session event editor address remove
- Api session event editor address set addition
- Api session event editor address set letter
- Api session event editor address set number
- Api session event editor address set street
- Api session event editor address set surface size
- Api session event editor address set zip code
