Api session event editor parametric
Revision as of 15:23, 30 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/
API Endpoints for Parametric editing.
Name Description
add Add new Parametric
append_attribute Appended to existing Parametric numeric Attribute value
duplicate Duplicate existing Parametric
remove Remove existing Parametric
remove_attribute Remove numeric Attribute from Parametric
set_attribute Set Parametric numeric Attribute value
set_attributes Set multiple Parametric numeric Attribute values
set_name Set new name of existing Parametric
set_polygons Set Polygons to existing Parametric
Additional API Endpoints:
Name Description
add_example Add Example
add_plot Add Plot
apply Apply
generate Generate
remove_plot Remove Plot
remove_plot_attributes Remove Plot Attributes
save_as_measure Save As Measure
set_alignment Set Alignment
set_function Set Function
set_plot_attributes Set Plot Attributes
set_plot_function Set Plot Function
