Waterway level change benchmark (Water Module)
In this benchmark, the ground water table is initially the same as the water level in the waterway. Then, the level in the waterway suddenly rises with h0 meters. This causes water to infiltrate into the ground, slowly raising the ground water table as well.
Situation of the waterway level change benchmark for groundwater
When the water level in the waterway changes, the water table level will also change over time. The relation between water level in the waterway and the ground water table at distance x from the waterway is described by the following formulas[1]:
In case the water level is raised, the following formula should hold:
h(x)h0=erfc(xS4kDt)
The formula erfc is the complementary error function.
In case the water level is lowered, the following formula should hold:
h(x)h0=erf(xS4kDt)
erf(z)=2π0zet2dt
erfc(z)=1erf(z)
h(x): change in phreatic groundwater table (m)
h0: change in water level in the waterway(m)
x: distance to the waterway (m)
t: time since the water level change
kD: transmissivity of the aquifer (m2 / day)
S: phreatic water storage fraction.
This graph shows the relative change in the ground water level after 1, 4, 9, 16, 25, 36, 49, 64, 81, 100 en 121 days, calculated using the mentioned formulas.
Setup
The test setup uses the same parameters used in the research results published in literature[2]. The grid chosen is 112 by 5. The ground water table comparisons will be conducted in the x-direction. The grid cell size is set to 25 meters.
The terrain height is set up as follows:
0.0 m for x <= 2
3.0 m for x == 3
10.0 m for x > 3
The initial water level is set to 2, for both surface and the groundwater table, by using a water area set to 2 meters.
The water will be raised to 4 meters, thereby simulating an h0 of 2.
An inlet at x=1, y=1-3 creates a sudden stable water level increase:
UPPER_THRESHOLD set to 4.
LOWER_THRESHOLD set to 4.
Inlet Q set to 0, such that is unlimited.
This ensures that the water level is instantly raised to level 4 and that it remains at 4 at all times.
The ground is setup with: Water storage fraction set to 0.25.
An aquifer is added for the region as well, initialized with the Aquifer KD set to 700 m2/day.
For the test different simulation times T are tested, each resulting in a different relation graph as shown in the described case above.
Use a ground water overlay and set the Weather's rain M parameter to [T, 0.0] for a rainless simulation of T seconds. Note that T has to be converted to days to be used in the formula's described above.
The surface water simulation mode is set to surface averaging.
Results
The results are generated for four simulation periods: 16 days, 64 days, 81 days and 121 days. The value h is the groundwater level increase (m), where the waterway rose from 2 to 4 meters. The dx is the distance in meters to the waterway. As shown below, the lines align well.
16 Days
64 Days
81 Days
121 Days
API Endpoints
  1. Quantitative Hydrogeology. Groundwater Hydrology for Engineers. Academic Press ∙ Marsily, Ghislain de, 1986. ∙ Page(s): 199 (originally in french)
  2. Verhoging van grondwaterstanden en vermindering van afvoer door opstuwing van beken. Overdruk uit Verslagen Technische Bijeenkomsten 11-12. Versl. Meded. Comm. Hydrol. Onderz. T.N.O. No. 3 (1958) ∙ Ernst, L.F. 1958
