How to verify available data in a Project Map
Revision as of 08:42, 14 July 2026 by Frank@tygron.nl (talk | contribs)
Once a new project is generated using Geo Plugins or data has been imported using the Geo Data Wizard, the Query Tool can be used to quickly verify if the project contains retrievable data.
How to verify available data in a Project Map:
  1. Select Current Situation in the ribbon
  2. Import area data from a WFS with a particular Attribute, for example SAFE_ZONE.
  3. Open the Query Tool by clicking on the button in the ribbon
  4. Paste the following query in the text area: SELECT_LANDSIZE_WHERE_AREA_WITH_ATTRIBUTE_IS_SAFE_ZONE
  5. Verify that the Query result returns a number larger than zero.
API Endpoints
