Api session event editor stakeholder
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorstakeholder/
API endpoints for Stakeholder editing.
Name Description
add Add new Stakeholder
duplicate Duplicate existing Stakeholder
remove Remove existing Stakeholder
set_active Set Stakeholder active
set_color Set new color of existing Stakeholder
set_name Set new name of existing Stakeholder
Additional API endpoints:
Name Description
add_land_ownership Add Land Ownership
add_with_type_and_active Add With Type And Active
select_stakeholder Select Stakeholder using the preferred ID; if unavailable, fall back to the next best option.
set_image Set Image
set_short_name Set Short Name
set_start_budget Set Start Budget
set_type Set Type
transfer_ownership Transfer Ownership
reset_web_token Reset Web Token
reset_web_token_with_length Reset Web Token With Length
