SimState
Revision as of 13:55, 10 July 2026 by Frank@tygron.nl (talk | contribs)
SimState reflects the current state of a session of your project.
Name Description Usage
NOTHING Waiting on map Selection The project is created but the location is not yet set. No Geo Data from Project Sources are yet obtained.
GEO_WIZARD Loading Geo Data Geo data is obtained for the project map and the project is filled with data.
NORMAL Base mode Normal state of the project, after the Geo wizard process has finished and after a test run has stopped. Users can edit the project while in this state.
TESTRUN Testing an Impact Session While in the editor a test-run is started, putting your session in this special mode. Stopping a test-run reverts the changes made and puts the project session back into NORMAL mode.
