Livability Housing (Indicator)
Revision as of 12:30, 7 July 2026 by Frank@tygron.nl (talk | contribs)
The Livability Housing indicator calculates the percentage of buildings with adequate living conditions. See the Livability Overlay for the livability scoring. The indicator panel shows these percentages per neighborhood. This indicator is useful for projects where for example:
  • one of the goals is to create a better neighborhood/environment for citizens
  • neighborhoods are compared
Indicator panel
The indicator panel shows the present neighborhoods in the area, the total amount of houses in each neighborhood and the percentage of houses with adequate livability conditions.
Calculation
This indicator calculates the percentage of houses with adequate livability conditions in each neighborhood. Houses in the Tygron Platform are referred to as units. A building block is not necessarily one unit. You can see the number of units when clicking on a building in the 3D Visualization. The livability of a house is considered 'adequate' if the livability score (calculated in the Livability Overlay is above -0.5. This score is based on function values of Buildings in the project.
Score
The score is represented in a progress bar, with a scale from 0 to 100%. Determine if you want to calculate the absolute or relative score. This value is the percentage of adequate houses relative to the total number of houses. At 0% there are no houses in the area with adequate livability. At 100% every house in the area has adequate livability conditions. The score can be adjusted in three ways:
  • The function values of Buildings in the project map can be changed, see Livability Overlay .
  • The threshold value for what adequate living is (now set to -0.5), can be adjusted in the indicator excel file.
  • Right now indicator target is for the houses in the area to be 100% adequate. The indicator target can be changed to a percentage below 100% in the excel file.
Additional configurations
For this indicator to function, the Livability Overlay needs to be added
Add the Livability Overlay
Follow these steps to add the Livability Overlay required for the indicator to calculate properly.
Livability Housing (Indicator):
  1. Select in the editor 'Current situation' from the ribbon
  2. Hover over 'Overlays' in the ribbon bar
  3. Select the Livability Overlay from the drop down menu
  4. Hover over the Auto update icon and choose for Reset to Start values (faster) to update your project.
