Iteration (TQL Param)
| Param | Value | Description | Limits search polygon |
| ITERATION | positive integer | Query only executes when the current Iteration matches this value | false |
Available for
- Select attribute (TQL)
- Select floorsize (TQL)
- Select global (TQL)
- Select height (TQL)
- Select id (TQL)
- Select gridavg (TQL)
- Select gridmin (TQL)
- Select gridmax (TQL)
- Select gridarea (TQL)
- Select gridvolume (TQL)
- Select gridstdev (TQL)
- Select landsize (TQL)
- Select landpolygons (TQL)
- Select lotsize (TQL)
- Select lotpolygons (TQL)
- Select name (TQL)
- Select units (TQL)
- Queries with these clauses are only executed when the current Iteration matches the value of this clause.
- If the current Iteration is not equal to the value of this clause, a cell in an Excel with this query is not written to. This behavior makes it different from other queries, which generally write a default value of 0.
- The same holds for update queries, which are also only executed when the iteration matches the value of this clause, and are ignored otherwise.
