Y (TQL)
Revision as of 12:05, 8 June 2026 by Frank@tygron.nl (talk | contribs) (Clause Parameters)
Instead of specifying a clause parameter with a particular Item ID, it is possible to use the 'Y' character for its value. The result of using 'Y' for the clause value, is the automatic creation of multiple TQL statements, one with each Item ID for that Clause Parameter that can be found in the project data. Internally, the resulting TQL statements are placed in an array of arrays; Similarly the result will be an array of TQL result arrays.
Example
Consider the following (simplified) Neighborhood data of a project:
 { "id" : 0, "name" : "De Manege" },
 { "id" : 1, "name" : "De Lancaster" },
 { "id" : 2, "name" : "De Landstreken" },
 { "id" : 3, "name" : "De Kruidentuin" },
 { "id" : 4, "name" : "Golfresidentie" }
The TQL statement
SELECT_NAME_WHERE_NEIGHBORHOOD_IS_Y
is internally replaced with a list of TQL statement arrays, separated by comma's,
 [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0 ], [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_1 ], [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_2 ], [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_3 ] , [ SELECT_NAME_WHERE_NEIGHBORHOOD_IS_4 ]
Its result will be an array of name arrays, separated by comma's, for example:
["De Manege"], ["De Lancaster"], ["De Landstreken"], ["De Kruidentuin"], ["Golfresidentie"]
Clause Parameters
The Y value can be used in the following TQL Clause parameters:
