ID (TQL)
Instead of specifying the value of a clause parameter with a particular Item ID, it is possible to use the 'ID' characters for its value. The result of using 'ID' for the clause value, is that is automatically filled in using the Item that contains the TQL statement.
ID clause values are often used in combination with Template Panels; For example: Consider A Template Text Panel applied on Neighborhoods
Example
Consider the following (simplified) Neighborhood data of a project:
{ "id" : 0, "name" : "East Side", "attributes": { "INHABITANTS": 600.0 } },
{ "id" : 1, "name" : "West Side", "attributes": { "INHABITANTS": 200.0 } }
And a Template Text Panel applied on Neighborhoods, resulting in two Text Panel instances:
"id" : 2, "mapLink" : "NEIGHBORHOODS", "name" : "Template Text Panel", "type" : "TEMPLATE_TEXT_PANEL",
"text" : "Name: $SELECT_NAME_WHERE_NEIGHBORHOOD_IS_ID<br>Inhabitants: $SELECT_ATTRIBUTE_WHERE_NEIGHBORHOOD_IS_ID_AND_NAME_IS_INHABITANTS"
"contentID" : 0, "contentMapLink" : "NEIGHBORHOODS", "id" : 3, "name" : "Template Text Panel: East Side", "parentID" : 2, "type" : "TEXT_PANEL"
"contentID" : 1, "contentMapLink" : "NEIGHBORHOODS", "id" : 4, "name" : "Template Text Panel: West Side", "parentID" : 2, "type" : "TEXT_PANEL"
The TQL statement
SELECT_NAME_WHERE_NEIGHBORHOOD_IS_ID is internally replaced with
SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0 for the first Text Panel and SELECT_NAME_WHERE_NEIGHBORHOOD_IS_1 for the second Text Panel, as these are the Neighborhoods each panel is linked to (using the contentID and contentMaplink parameters).
The result of each query will be:
"East Side" and "West Side"
Similarly, the value of the attribute INHABITANTS of the linked Neighborhood can be obtained using
SELECT_ATTRIBUTE_WHERE_NEIGHBORHOOD_IS_ID_AND_NAME_IS_INHABITANTS.
Clause Parameters
The X value can be used in the following TQL Clause parameters:
