Categorymult (TQL Param)
| Param | Value | Description | Limits search polygon |
| Multiply the calculated value with this Category Value of a Building |
Available for
- Select floorsize (TQL)
- Select height (TQL)
- Select lotpolygons (TQL)
- Select lotsize (TQL)
- Select name (TQL)
- Select units (TQL)
- This clause uses the attribute specified for a Category Value
- This clause should generally be used in for Select floorsize (TQL).
- In case this clause is used in combination with the Category (TQL Param), this category value is only multiplied for that category.
- In case this clause is not used in combination with the Category (TQL Param), the weighted average of this value is calculated, using a Building's Categories and their Category weight (Category Value).
