Grid (TQL Param)
| Param | Value | Description | Limits search polygon |
| Grid of Grid Overlay with ID |
Available for
- Select attribute (TQL)
- Select floorsize (TQL)
- Select height (TQL)
- Select id (TQL)
- Select gridavg (TQL)
- This parameter requires that you know the grid's ItemID. If you want to create a query that is used in multiple projects, you can also opt for Grid with attribute (TQL Param).
- In order to limit the search polygon, an additional Gridvalue (TQL Param), Mingridvalue (TQL Param) or Maxgridvalue (TQL Param) is required.
