Api session items actionmenus
Revision as of 12:37, 20 April 2026 by Frank@tygron.nl (talk | contribs)
Api session items Action Menus Endpoints.
Edit items with event: editoractionmenu.
Default Query:
https://engine.tygron.com/api/session/items/actionmenus/?f=JSON&token=API_TOKEN
Example Response:
  "attributeActionIDs" : [ ],
  "buildable" : {
    "0" : [ 0 ]
  "color" : null,
  "eventBundleIDs" : [ ],
  "functionIDs" : [ 436, 438 ],
  "id" : 0,
  "imageName" : "category_road.png",
  "imageVersion" : 0,
  "leveeIDs" : [ ],
  "measureIDs" : [ ],
  "name" : "Roads",
  "sortIndex" : 1,
  "specialOptions" : [ ],
  "upgradeIDs" : [ ],
  "version" : 16
  "buildable" : {
    "0" : [ 0 ]
  "color" : null,
  "functionIDs" : [ 77 ],
  "id" : 1,
  "imageName" : "category_heart.png",
  "imageVersion" : 0,
  "leveeIDs" : [ ],
  "measureIDs" : [ ],
  "name" : "Leisure",
  "sortIndex" : 2,
  "upgradeIDs" : [ ],
  "version" : 17
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/actionmenus/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/actionmenus/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/actionmenus/size/?token=API_TOKEN
Action Menus (GeoJSON):
https://engine.tygron.com/web/actionmenus.geojson?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/actionmenus/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/actionmenus/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/actionmenus/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/actionmenus/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/actionmenus/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/actionmenus/?f=ZIPSMILE&token=API_TOKEN
Api Model ActionLog
API Model description of ActionLog
Name Type Description
action ParticipantEventType
budget double
buildingIDs int[]
id int
itemID int
mapLink MapLink
mp MultiPolygon
point Point
scoreAfter Map<int,double>
scoreBefore Map<int,double>
simTime long
stakeholderID int Stakeholder ID
subject String
version int
Api Model ActionMenu
API Model description of ActionMenu
attributeActionIDs int[] Attribute Action ID
buildable Map<int,java.util.List<java.lang.Integer>>
color TColor
eventBundleIDs int[] Event Bundle ID
functionIDs int[] Function ID
id int
imageName String
imageVersion int
leveeIDs int[] Levee ID
measureIDs int[] Measure ID
name String
sortIndex int
specialOptions Type[]
upgradeIDs int[] Upgrade Type ID
version int
Api Model ActionType
API Enumeration description of ActionType
Name Description
CONSTRUCTION_PLAN
CONSTRUCTION_PLAN_CANCEL
Api Model Addition
API Model description of Addition
amount int
animMultiplier double
name String
randomScale double
show Show
Api Model Address
API Model description of Address
addition String
attributes Map<String,double[]>
id int
letter String
maquetteOverride Map<String,double[]>
name String
number int
point Point
sourceIDs int[] Source ID
street String
surfaceSize double
type String
version int
zipCode String
Api Model AddressAttribute
API Enumeration description of AddressAttribute
Name Description
ENERGY_LABEL
CADASTRAL_PURPOSE
RESIDENCE_TYPE
INHABITANTS
FLOOR_SPACE_M2
Api Model AeriusOverlay
API Model description of AeriusOverlay
colorMultiplier double
colorOffset int
customLegend boolean
id int
imageName String
imageVersion int
legend LegendEntry[]
name String
parentID int Overlay ID
sortIndex int
type OverlayType
version int
visible boolean
Api Model Alignment
API Enumeration description of Alignment
Name Description
ROAD
SPACED
Api Model Answer
API Model description of Answer
clientEvents CodedEvent[]
contents String
events CodedEvent[]
id int
selected boolean
Api Model Area
API Model description of Area
center Point
id int
name String
polygons MultiPolygon
relations Map<Relation,int>
version int
Api Model AreaAttribute
API Enumeration description of AreaAttribute
Name Description
ACTIVE
NATURE_RESERVE
INTEREST_AREA
Api Model AreaOverlay
API Model description of AreaOverlay
areaIDs int[] Area ID
colorOffset int
id int
imageName String
imageVersion int
name String
remainderColor TColor
sortIndex int
type OverlayType
version int
visible boolean
Api Model AssetValue
API Enumeration description of AssetValue
Name Description
NAME
DESCRIPTION
ID
IMAGELOCATION
ROOF_COLOR
BASEMENT_COLOR
GROUND_COLOR
EXTRA_COLOR
TOP_COLOR
Api Model AttributeItem
API Model description of AttributeItem
id int
name String
version int
Api Model AttributeKey
API Enumeration description of AttributeKey
Name Description
A
B
C
D
E
F
G
H
I
J
Api Model AttributeOverlay
API Model description of AttributeOverlay
attribute String
attributeColor TColor
colorAttribute String
colorOffset int
id int
imageName String
imageVersion int
mapLink MapLink
name String
restColor TColor
sortIndex int
type OverlayType
version int
visible boolean
Api Model AttributeOverlayPredicate
API Model description of AttributeOverlayPredicate
attribute String
mapLink MapLink
Api Model AvgModelAttribute
API Enumeration description of AvgModelAttribute
Name Description
DISTANCE_M
ATTRIBUTE_TIMEFRAMES
DEFAULT_VALUE
SURFACE_ONLY
Api Model AvgOverlay
API Model description of AvgOverlay
active boolean
calcTimeMS long
colorOffset int
diffLegend LegendEntry[]
id int
imageName String
imageVersion int
inActiveCellSize double
inActiveTimeframes int
keys Map<String,String>
layerMapLink MapLink
maxValue float[]
minValue float[]
name String
prequels Map<String,PrequelLink>
rasterization Rasterization
resultType String
showDifference boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
API Model description of BGTFunctionLink
categories Category[]
className String
functionID int Function ID
id int
layer BGTLayer
priority int
transmissionTowerFoundations int
tree boolean
typeName String
version int
Api Model BGTLayer
API Enumeration description of BGTLayer
Name Description
BAK
BEGROEIDTERREINDEEL
BORD
BUURT
FUNCTIONEELGEBIED
GEBOUWINSTALLATIE
INSTALLATIE
KAST
KUNSTWERKDEEL
MAST
ONBEGROEIDTERREINDEEL
ONDERSTEUNENDWATERDEEL
ONDERSTEUNENDWEGDEEL
ONGECLASSIFICEERDOBJECT
OPENBARERUIMTE
OPENBARERUIMTELABEL
OVERBRUGGINGSDEEL
OVERIGBOUWWERK
OVERIGESCHEIDING
PAAL
PUBLIC
PAND
PLAATSBEPALINGSPUNT
PUT
SCHEIDING
SENSOR
SPOOR
STRAATMEUBILAIR
TUNNELDEEL
VEGETATIEOBJECT
WATERDEEL
WATERINRICHTINGSELEMENT
WEGDEEL
WEGINRICHTINGSELEMENT
WIJK
API Model description of BGTTerrainLink
className String
id int
layer BGTLayer
priority int
terrainTypeID int Terrain Type ID
typeName String
version int
Api Model BaseAttribute
API Enumeration description of BaseAttribute
Name Description
COLOR
Api Model BaseFunction
API Model description of BaseFunction
constructionPeriods ConstructionPeriod[]
decals Map<FaceType,float[]>
defaults Type[]
description String
dimension int
id int
imageName String
modelSetID int Model Set ID
name String
placementType PlacementType
regions Region[]
textures Map<FaceType,String>
version int
Api Model BridgeElevation
API Enumeration description of BridgeElevation
Name Description
LOWEST
TERRAIN
BRIDGE
Api Model Building
API Model description of Building
addressIDs int[] Address ID
center Point
customGeometries CGLink[]
demolisherID int Stakeholder ID
id int
measureID int Measure ID
modelVersion int
name String
overrideCategories Category[]
overrideDecals Map<FaceType,float[]>
ownerID int Stakeholder ID
permitReceived Map<int,Boolean>
predecessorID int Building ID
sections Section[]
state TimeState
upgradeID int Upgrade Type ID
upgradeOwnerID int Stakeholder ID
version int
Api Model BuildingAttribute
API Enumeration description of BuildingAttribute
Name Description
CONSTRUCTION_FINISH_DATE
POWER_LINE_BUILDING_ID
MODEL_ANGLE
POPULATION_DENSITY_M2
GEOMETRY_COLOR
VACANT
PRIVATE_YARD
API Model description of CGLink
geometryID int Custom Geometry ID
primary boolean
Api Model Category
API Enumeration description of Category
Name Description
SOCIAL
NORMAL
LUXE
ROAD
PAVED_AREA
EDUCATION
HEALTHCARE
PARK
NATURE
INDUSTRY
OFFICES
OTHER
SENIOR
UNDERGROUND
SHOPPING
AGRICULTURE
LEISURE
STUDENT
GARDEN
INTERSECTION
BRIDGE
Api Model CategoryZone
API Model description of CategoryZone
allowedCategories Category[]
center Point
excelID int Excel Sheet ID
excelUpdated boolean
id int
name String
outline Outline
parentZoneID int Zone ID
permitterID int Stakeholder ID
version int
Api Model ClimateModel
API Model description of ClimateModel
endTemp double
endYear int
oxidation double
soilTempFactor double
startTemp double
startYear int
Api Model CodedEvent
API Model description of CodedEvent
id int
parameters Object[]
Api Model ComboModelAttribute
API Enumeration description of ComboModelAttribute
Name Description
ATTRIBUTE_DEFAULT_VALUE
ATTRIBUTE_SURFACE_ONLY
Api Model ComboOverlay
API Model description of ComboOverlay
active boolean
calcTimeMS long
colorOffset int
formula String
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model ConstructionPeriod
API Enumeration description of ConstructionPeriod
Name Description
ANCIENT
CLASSIC
PRE_WAR
POST_WAR
CONTEMPORARY
FUTURISTIC
Api Model CoreStakeholder
API Model description of CoreStakeholder
active boolean
client ClientData
color TColor
id int
lastSelected long
name String
version int
webToken String
Api Model CostType
API Enumeration description of CostType
Name Description
CONSTRUCTION
Api Model CustomColorArea
API Model description of CustomColorArea
color TColor
name String
zoneID int
Api Model CustomGeometry
API Model description of CustomGeometry
absoluteHeight boolean
backFaceCulling boolean
color TColor
data float[]
id int
texture String
version int
Api Model DataType
API Enumeration description of DataType
Name Description
FLOAT
DOUBLE
INT8
INT16
INT32
INT64
BOOL
STRING
UINT8
FLOAT16
BFLOAT16
UNKNOWN
Api Model DefaultAttribute
API Enumeration description of DefaultAttribute
Name Description
ATTRIBUTE
Api Model DefaultNeuralNetwork
API Model description of DefaultNeuralNetwork
description String
id int
legendEntries LegendEntry[]
name String
override boolean
producer String
tensors Tensor[]
uploadDate long
uploaderName String
version int
warnings String
Api Model DefaultOverlay
API Model description of DefaultOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DefaultRasterizationOverlay
API Model description of DefaultRasterizationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DefaultResult
API Enumeration description of DefaultResult
Name Description
DEFAULT
Api Model DefaultSource
API Model description of DefaultSource
color TColor
date long
description String
id int
infoUrl String
name String
uploaderName String
version int
Api Model DesignAttribute
API Enumeration description of DesignAttribute
Name Description
BACKYARD_DISTANCE_M
WATER_WIDTH_M
KEEP_EXISTING_ROADS
ROAD_WIDTH_M
ROAD_DISTANCE_Y_M
ROAD_SEARCH_DISTANCE_M
SIDEWALK_WIDTH_M
PARKING_WIDTH_M
PARKING_LENGTH_M
FRACTION_BUILDINGS
FRACTION_ROADS
FRACTION_WATER
FRACTION_PUBLIC_GREEN
FRACTION_GARDENS
FRACTION_PARKING
FRACTION_REMAINDER
Api Model Detail
API Enumeration description of Detail
Name Description
CONSTRUCTION_COST
DEMOLISH_COST
BUYOUT_COST
SELL_PRICE
SELLABLE_FLOORSPACE_M2
NUMBER_OF_HOUSES
Api Model DischargeMethod
API Enumeration description of DischargeMethod
Name Description
HEIGHT_MINIMA
WATER_TERRAINS
AREAS
Api Model DistanceOverlay
API Model description of DistanceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model DistanceResult
API Enumeration description of DistanceResult
Name Description
ZONE
SIGHT
Api Model EmptyMultiPolygon
API Model description of EmptyMultiPolygon
Api Model EnergyLabel
API Enumeration description of EnergyLabel
Name Description
UNKNOWN
G
F
E
D
C
B
A0
A1
A2
A3
A4
A5
Api Model EventBundle
API Model description of EventBundle
compoundEventBundleIDs int[] Event Bundle ID
description String
id int
imageName String
imageVersion int
name String
serverEvents CodedEvent[]
version int
Api Model Example
API Enumeration description of Example
Name Description
CITY_NEIGHBORHOOD
URBAN_NEIGHBORHOOD
SUBURBAN_NEIGHBORHOOD
WINDMILL_AREA
Api Model ExcelPanel
API Model description of ExcelPanel
answers Answer[]
calcTimeMS long
contentID int
contentMapLink MapLink
height double
id int
layoutX double
layoutY double
name String
overlayID int Overlay ID
overrideDefaultAnswerID int
parentID int
point Point
text String
type PanelType
updateTiming Timing
version int
warnings String
width double
Api Model FaceType
API Enumeration description of FaceType
Name Description
BASEMENT
GROUND
EXTRA
TOP
ROOF
Api Model FloodingOverlay
API Model description of FloodingOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
weatherID int Weather ID
API Model description of FunctionChangeGeoLink
add boolean
category Category
featureAttributes Map<String,java.util.List<java.lang.String>>
id int
priority int
tree boolean
update boolean
version int
Api Model FunctionOverlay
API Model description of FunctionOverlay
colorOffset int
functionsColor TColor
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model FunctionOverride
API Model description of FunctionOverride
description String
id int
imageName String
imageVersion int
name String
version int
Api Model FunctionType
API Enumeration description of FunctionType
Name Description
ROAD
WATER
PARKING
SIDEWALK
BUILDING
GARDEN
PUBLIC_GREEN
REMAINDER
Api Model GasType
API Enumeration description of GasType
Name Description
NOX
NO2
Api Model GeoFormat
API Enumeration description of GeoFormat
Name Description
GEOJSON
GEOPACKAGE
WFS_JSON
WFS_GML
WMS_IMAGE
WCS_TIFF
OSM
BGT_GML
ESRI_JSON
ESRI_IMAGE
CYCLO_IMAGE
I3S
GEOTIFF
DXF
Api Model GeoTiffAttribute
API Enumeration description of GeoTiffAttribute
Name Description
BAND
Api Model GeoTiffFeature
API Model description of GeoTiffFeature
id int
version int
Api Model GeoTiffOverlay
API Model description of GeoTiffOverlay
active boolean
calcTimeMS long
colorOffset int
geoTiffIDs int[] GeoTIFF ID
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model GeoTiffResult
API Enumeration description of GeoTiffResult
Name Description
NEAREST
INTERPOLATED
Api Model GeoTiffSpatial
API Model description of GeoTiffSpatial
autoMP boolean
id int
multiPolygon MultiPolygon
terrainTypeID int
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model Global
API Model description of Global
actualValue double[]
bookValueStakeholderID int Stakeholder ID
calcTimeMS long
id int
name String
point Point
previousValue double[]
query String
queryTiming Timing
startValue double[]
version int
visualisationName String
Api Model GlobalPanel
API Model description of GlobalPanel
answers Answer[]
globalIDs int[] Global ID
height double
id int
layoutX double
layoutY double
name String
point Point
type PanelType
version int
width double
Api Model GridFeature
API Model description of GridFeature
id int
version int
Api Model GridModelAttribute
API Enumeration description of GridModelAttribute
Name Description
ITERATION_ACTIVE
SKIP_NO_DATA
GPU_CLUSTER_INDEX
Api Model GridOverlay
API Model description of GridOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model GridSpatial
API Model description of GridSpatial
autoMP boolean
id int
overlayIDs int[] Overlay ID
terrainTypeID int
Api Model GroundwaterOverlay
API Model description of GroundwaterOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model Group (SpecialOption)
API Enumeration description of Group
Name Description
LAND
SCULPTING
FINANCE
DEMOLISH
Api Model HeatDpraAttribute
API Enumeration description of HeatDpraAttribute
Name Description
DATES
DAILY_AVG_RADIATION
DAILY_TEMPERATURE_MAX
DAILY_TEMPERATURE_MIN
EXCLUDE_BUILDINGS
EXCLUDE_WATER
EXCLUDE_FOLIAGE_HEIGHT_M
FOLIAGE_AREAS
HOURLY_RADIATION
HOURLY_TEMPERATURE
HOURLY_HUMIDITY
SUN_ALTITUDE
SUN_AZIMUTH
SUN_DAILY_MOTION
WIND_DIRECTION
WIND_SPEED
DAILY_AVG_WIND_SPEED
MAX_SHADOW_DISTANCE
MAX_TRUNK_DISTANCE
WIND_DECLINE_ANGLE
Api Model HeatKey
API Enumeration description of HeatKey
Name Description
FOLIAGE_HEIGHT
Api Model HeatModel
API Enumeration description of HeatModel
Name Description
UNESCO
DPRA
Api Model HeatOverlay
API Model description of HeatOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
model HeatModel
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model HeatPrequel
API Enumeration description of HeatPrequel
Name Description
FOLIAGE_HEIGHT
BUILDING_ELEVATION
TERRAIN_ELEVATION
Api Model HeatResult
API Enumeration description of HeatResult
Name Description
BOWEN_RATIO
FOLIAGE
PET
PET_RELATIVE
SHADE
SKY_VIEW
SKY_VIEW_AVG
TEMPERATURE_ATMOSPHERE
UHI
VEGETATION
VEGETATION_AVG
WIND_SPEED
Api Model HeightAttribute
API Enumeration description of HeightAttribute
Name Description
ZONING_PERMIT_REQUIRED
Api Model HeightOperator
API Enumeration description of HeightOperator
Name Description
AVG
MIN
MAX
VOLUME
STDEV
AREA
Api Model HeightOverlay
API Model description of HeightOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model HeightResult
API Enumeration description of HeightResult
Name Description
DSM
DTM
FLOORS
Api Model HeightSector
API Model description of HeightSector
changed Boolean
envelope Envelope
id int
name String
pointAreaM2 double
pointWidth int[]
square MultiPolygon
version int
Api Model HeightSquare
API Model description of HeightSquare
x double
xMax double
xMin double
y double
yMax double
yMin double
Api Model ImageAttribute
API Enumeration description of ImageAttribute
Name Description
ALPHA
Api Model ImageOverlay
API Model description of ImageOverlay
colorOffset int
id int
imageName String
imageNames String[]
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model Indicator
API Model description of Indicator
absolute boolean
calcTimeMS long
currentExplanation String
description String
exactNumberValues Map<MapType,double>
exactTextValues Map<MapType,String>
id int
imageName String
imageVersion int
isActive boolean
mapTypeValues Map<MapType,double>
maquetteExplanation String
name String
parentID int Indicator ID
shortName String
sortIndex int
targetDescriptions String[]
targets Map<int,double[]>
updateTiming Timing
version int
warnings String
Api Model IndicatorAttribute
API Enumeration description of IndicatorAttribute
Name Description
FINANCE
Api Model InferenceAttribute
API Enumeration description of InferenceAttribute
Name Description
MASK_THRESHOLD
SCORE_THRESHOLD
INFERENCE_MODE
STRIDE_FRACTION
BOX_OVERLAP
PRIORITIZE_LABELS
GPU_MEMORY_MB
Api Model InferenceMode
API Enumeration description of InferenceMode
Name Description
CLASSIFICATION
BBOX_DETECTION
Api Model InferenceOverlay
API Model description of InferenceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
neuralNetworkID int Neural Network ID
resultType String
sortIndex int
tensorLinks TensorLink[]
type OverlayType
version int
visible boolean
warnings String
Api Model InferencePrequel
API Enumeration description of InferencePrequel
Name Description
A
B
C
Api Model InferenceResult
API Enumeration description of InferenceResult
Name Description
LABELS
SCORES
BOXES
MASKS
DEBUG_GT_INSTANCES
CENTER_POINTS
Api Model Input
API Enumeration description of Input
Name Description
A
B
C
D
E
F
G
H
I
J
Api Model InstanceColor
API Enumeration description of InstanceColor
Name Description
GRAY
WHITE
VEGIE_GREEN
GRAIN_YELLOW
FLOWERS
Api Model Item
API Model description of Item
id int
version int
Api Model ItemMeasurement
API Model description of ItemMeasurement
id int
itemID int
key String
mapLink MapLink
maqMax double
maqMin double
max double
min double
name String
overlayMaqValues Map<int,float[]>
overlayValues Map<int,float[]>
point Point
save boolean
sum boolean
version int
Api Model IterationAttribute
API Enumeration description of IterationAttribute
Name Description
MODULUS
TIMEFRAME_TIMES
Api Model IterationOverlay
API Model description of IterationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model IterationPrequel
API Enumeration description of IterationPrequel
Name Description
ITERATION
Api Model Layer
API Enumeration description of Layer
Name Description
BRIDGE
SURFACE
UNDERGROUND
Api Model LegendEntry
API Model description of LegendEntry
color TColor
entryName String
id int
value float
Api Model LeveeFeature
API Model description of LeveeFeature
id int
version int
Api Model LeveeSpatial
API Model description of LeveeSpatial
angleOverride double
heightOverride double
id int
isRelativeOverride Boolean
leveeID int Levee ID
sidePolygon MultiPolygon
topPolygon MultiPolygon
Api Model LimitType
API Enumeration description of LimitType
Name Description
DEFAULT
NEIGHBORHOODS
MEASURE_NEIGHBORHOODS
Api Model LineMeasurement
API Model description of LineMeasurement
distances double[]
id int
lineSegment LineSegment
lineString LineString
maqMax double
maqMin double
maqValues Map<int,java.util.ArrayList<float[]>>
max double
min double
name String
save boolean
sum boolean
values Map<int,java.util.ArrayList<float[]>>
version int
Api Model LineString
API Model description of LineString
Api Model LoadAttribute
API Enumeration description of LoadAttribute
Name Description
CONNECTION_COST
FLOW
POWER
CONNECTION_COUNT
FLOOR_SPACE_M2
TYPE
ROOT_LOAD
LOAD_COUNT
ADDRESS_COUNT
CONNECTION_FRACTION
PRESSURE_M_H2O_SUPPLY
PRESSURE_M_H2O_RETURN
TEMPERATURE_SUPPLY_DEGREES_CELSIUS
Api Model LoadCostSegment
API Model description of LoadCostSegment
baseCost double
incrCost double
minValue int
Api Model LoadParameterType
API Enumeration description of LoadParameterType
Name Description
FLOW
POWER
CONNECTION_COST
CONNECTION
FLOOR_SPACE_M2
Api Model LoadType
API Enumeration description of LoadType
Name Description
UNKNOWN
COLLECTIVE
COLLECTIVE_TAP
COLLECTIVE_RADIATOR
COLLECTIVE_RADIATOR_TAP
INDIVIDUAL
LARGE_SCALE_CONSUMER
Api Model LogicPanel
API Model description of LogicPanel
answers Answer[]
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
name String
parentID int
point Point
text String
type PanelType
updateTiming Timing
version int
warnings String
width double
Api Model MapMeasure
API Model description of MapMeasure
actualHeightChangeM3 double
buildingIDs int[] Building ID
buildingPermitProcessed Set
center Point
clientActionEvents Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>>
confirmationsRequired boolean
constructionCostsFixed double
constructionCostsM3 double
custom boolean
dependencyIDs int[] Measure ID
description String
geoTiffSpatials GeoTiffSpatial[]
gridSpatials GridSpatial[]
id int
imageName String
imageVersion int
incomeFixed double
landOwnerPermissions Map<int,Boolean>
leveeSpatials LeveeSpatial[]
name String
serverActionEvents Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>>
state TimeState
terrainSpatials TerrainSpatial[]
upgradeSpatials UpgradeSpatial[]
version int
Api Model MapType
API Enumeration description of MapType
Name Description
CURRENT
MAQUETTE
Api Model Measure
API Model description of Measure
custom boolean
description String
id int
imageName String
imageVersion int
incomeFixed double
name String
state TimeState
version int
Api Model MeasureEditType
API Enumeration description of MeasureEditType
Name Description
BUILDING
RAISE
FLATTEN
WATER
UPGRADE
LEVEE
GEOTIFF
GRID
Api Model Method
API Enumeration description of Method
Name Description
GET
POST
Api Model MinMax
API Enumeration description of MinMax
Name Description
NEVER
LARGE_CELL
ALWAYS
Api Model Mode
API Enumeration description of Mode
Name Description
SPEED
AVERAGE
ACCURACY
Api Model ModelData
API Model description of ModelData
additions Addition[]
buffer int
dimension int
frequency int
id int
instanceColor InstanceColor
isAlpha boolean
isShowCloseby boolean
modelHeight double
modelWidth double
name String
particleEmitters ParticleEmitterCoordinatePair[]
placement Placement
randomScale double
roots boolean
rotation Rotation
show Show
variation int
version int
Api Model ModelStyle
API Enumeration description of ModelStyle
Name Description
WIREFRAME
PLAIN
COLORED
TEXTURED
DISCO
Api Model MultiLineString
API Model description of MultiLineString
Api Model MultiPolygon
API Model description of MultiPolygon
Api Model NO2Overlay
API Model description of NO2Overlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model NO2Result
API Enumeration description of NO2Result
Name Description
CONCENTRATION
EMISSION_NO2
EMISSION_NOX
TREEFACTOR
TREES
Api Model NeighborPredicate
API Model description of NeighborPredicate
me Building
Api Model Neighborhood
API Model description of Neighborhood
center Point
id int
municipalityID int Stakeholder ID
name String
version int
Api Model NeighborhoodAttribute
API Enumeration description of NeighborhoodAttribute
Name Description
URBANIZATION
INHABITANTS
ACTIVE
Api Model NetFunction
API Model description of NetFunction
diameterM double
groupName String
id int
name String
netType NetType
priceM double
version int
Api Model NetLine
API Model description of NetLine
endNodeID int Net Node ID
functionID int Net Function ID
id int
name String
startNodeID int Net Node ID
version int
Api Model NetLineAttribute
API Enumeration description of NetLineAttribute
Name Description
FLOW
DIAMETER_M
ALWAYS_ACTIVE
Api Model NetLineFunctionAttribute
API Enumeration description of NetLineFunctionAttribute
Name Description
PRICE_M
VISUALIZATION_DIAMETER_M
DIAMETER_M
COLOR
Api Model NetLoad
API Model description of NetLoad
buildingID int Building ID
clusterID int Net Cluster ID
connectionState TimeState
id int
name String
netType NetType
nodeID int Net Node ID
point Point
version int
Api Model NetNode
API Model description of NetNode
connectedLineIDs int[]
id int
loadIDs int[]
name String
point Point
version int
Api Model NetOverlay
API Model description of NetOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
netType NetType
showActive boolean
showNetwork boolean
sortIndex int
type OverlayType
version int
visible boolean
Api Model NetType
API Enumeration description of NetType
Name Description
ELECTRICITY
GAS
HEAT
INTERNET
SEWER
Api Model NeuralNetwork
API Model description of NeuralNetwork
description String
id int
name String
producer String
tensors Tensor[]
uploadDate long
uploaderName String
version int
warnings String
Api Model NeuralNetworkAttribute
API Enumeration description of NeuralNetworkAttribute
Name Description
MIN_CELL_SIZE_M
MAX_CELL_SIZE_M
MAX_GT_INSTANCES
VERSION
Api Model NoPrequel
API Enumeration description of NoPrequel
Name Description
Api Model NoiseOverlay
API Model description of NoiseOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model NoiseResult
API Enumeration description of NoiseResult
Name Description
NOISE_DB
EMISSION
Api Model Operator (AvgOverlay)
API Enumeration description of Operator
Name Description
AVG
AVG_INTERPOLATED
MAX
MIN
Api Model Operator (ComboOverlay)
Name Description
SIN
COS
TAN
ASIN
ACOS
ATAN
SQRT
ROUND
FLOOR
CEIL
ABS
EXP
LN
LOG
RANDOM
ERF
GTE
GT
LTE
LT
NEQ
EQ
IF
AND
OR
SWITCH
ADD
MUL
DIV
SUB
MAX
MIN
AVG
POW
PERCENTILE
AVG_GTE_PERCENTILE
AVG_LTE_PERCENTILE
COLOR
RED
GREEN
BLUE
ALPHA
Api Model Outline
API Enumeration description of Outline
Name Description
NONE
SIMPLE
DASHED
Api Model Overlay
API Model description of Overlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model OverlayCategory
API Enumeration description of OverlayCategory
Name Description
ADMINISTRATIVE
ENVIRONMENTAL
WATER
GRID_CALCULATION
GEO_DATA
TOPOGRAPHY
NETWORKS
Api Model OverlayType
API Enumeration description of OverlayType
Name Description
OWNERSHIP
OWNERSHIP_GRID
ZIP_CODES
ZONING
NEIGHBORHOODS
MUNICIPALITIES
SCENARIO
VACANCY
HEAT_STRESS
SHADOW
TRAFFIC_DENSITY
TRAFFIC_NO2
TRAFFIC_NOISE
LIVABILITY
AERIUS
RAINFALL
FLOODING
GROUNDWATER
WATERSHED
SUBSIDENCE
WATERWIJZER
AVG
COMBO
DISTANCE
SIGHT_DISTANCE
TRAVEL_DISTANCE
INFERENCE
ITERATION
GEO_TIFF
WMS
WCS
AREA
ATTRIBUTE
FUNCTION
SATELLITE
HEIGHTMAP
UNDERGROUND
SOURCE
NETWORK_OWNERSHIP
NETWORK_OVERVIEW
NETWORK_DISTANCE
RESULT_CHILD
TEST
DISTURBANCE_DISTANCE
SAFETY_DISTANCE
DEPRECATED
Api Model PDResult
API Model description of PDResult
areaExisting Map<FunctionType,double>
bandMPs Map<FunctionType,java.util.Map<java.lang.Integer, java.util.List<org.locationtech.jts.geom.MultiPolygon>>>
detailMPs Map<FunctionType,java.util.Map<java.lang.Integer, java.util.List<org.locationtech.jts.geom.MultiPolygon>>>
Api Model Panel
API Model description of Panel
answers Answer[]
height double
id int
layoutX double
layoutY double
name String
point Point
type PanelType
version int
width double
Api Model PanelAttribute
API Enumeration description of PanelAttribute
Name Description
VISIBLE
REFRESH
VISIBLE_TIMEFRAME
ATTENTION
SCALE
POPUP_TYPE
Api Model PanelTemplate
API Enumeration description of PanelTemplate
Name Description
TRAFFIC_NOISE
DANGEROUS_OBJECTS
NETWORK_INTERACTION
WATER_AREAS
WEIRS
Api Model PanelType
API Enumeration description of PanelType
Name Description
GLOBAL_PANEL
EXCEL_PANEL
WEB_PANEL
TEXT_PANEL
TEMPLATE_EXCEL_PANEL
TEMPLATE_TEXT_PANEL
Api Model ParametricDesign
API Model description of ParametricDesign
alignment Alignment
center Point
gardenID int Function ID
id int
name String
parkingID int Function ID
plotDesigns PlotDesign[]
publicGreenID int Function ID
roadID int Function ID
sidewalkID int Function ID
version int
waterID int Terrain Type ID
Api Model ParticleEmitterCoordinatePair
API Model description of ParticleEmitterCoordinatePair
id int
offsetCoordinate double[]
particleEmitterID int Particle Emitter ID
Api Model Placement
API Enumeration description of Placement
Name Description
POINT
EDGE
Api Model PlacementType
API Enumeration description of PlacementType
Name Description
WATER
LAND
HYBRID
Api Model Plot
API Model description of Plot
center Point
id int
name String
version int
Api Model PlotDesign
API Model description of PlotDesign
id int
Api Model PlotDesignAttribute
API Enumeration description of PlotDesignAttribute
Name Description
AREA_M2
WIDTH_M
SIDE_DISTANCE_M
ROAD_DISTANCE_M
UNITS
FLOORS
FLOOR_HEIGHT_M
FIT_FRACTION
FRACTION
Api Model Point
API Model description of Point
Api Model PointMeasurement
API Model description of PointMeasurement
id int
maqMax double
maqMin double
max double
min double
name String
point Point
save boolean
sum boolean
version int
Api Model PolygonAttributeItem
API Model description of PolygonAttributeItem
center Point
id int
name String
version int
Api Model PopupData
API Model description of PopupData
answers Answer[]
calendar long
color TColor
id int
imageType PopupImageType
linkID int
linkType MapLink
modelDataID int Model Data ID
modelType PopupModelType
name String
opensAutomatically boolean
overrideAttention Boolean
point Point
scale double
text String
title String
type Type
version int
visibleForStakeholderIDs int[] Stakeholder ID
visibleTimeframe int
Api Model PopupImageType
API Enumeration description of PopupImageType
Name Description
PICK_DATE
REQUEST_PERMIT
RECEIVE_REQUEST
WAITING
DECLINE
APPROVE
WAIT_BUILD
WAIT_DEMOLISH
BUILD_PROGRESS
DEMOLISH_PROGRESS
BUY_LAND
SELL_LAND
Api Model PopupModelType
API Enumeration description of PopupModelType
Name Description
APPROVED
ARROW
BUY
CONNECT_ON
CONNECT_OFF
CONSTRUCTING
ELEVATION
DECLINED
DEMOLISHING
WAITING
QUESTION_MARK
TRAFFIC_NOISE
WATER_CRANE
WATER_ARROW
WATER_WEIR
LIGHT_BULB
LIGHTNING
BAR_CHART
EXCLAMATION
Api Model RainOverlay
API Model description of RainOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model Rasterization
API Enumeration description of Rasterization
Name Description
FIRST
MIN
MAX
SINGLE_LAYER
GRID
Api Model RasterizationMethod
API Enumeration description of RasterizationMethod
Name Description
COMBINED
OUTLINE
CENTER
Api Model RasterizationOverlay
API Model description of RasterizationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model RasterizationPrequel
API Enumeration description of RasterizationPrequel
Name Description
INPUT
Api Model Region
API Enumeration description of Region
Name Description
NORTH_AMERICA
NORTHWESTERN_EUROPE
ASIA
AFRICA
OTHER
Api Model Relation
API Enumeration description of Relation
Name Description
OWNER
CONSTRUCTOR
DEMOLISHER
PERMITTER
SENDER
RECEIVER
NETOWNER
BORDER_A
BORDER_B
BUILDING
WEATHER
PARENT
RESULT_PARENT
Api Model ResidenceType (Address)
API Enumeration description of ResidenceType
Name Description
UNKNOWN
DETACHED
SEMI_DETACHED
PORCH
TERRACED_BETWEEN
TERRACED_CORNER
TINY
GALLERY_HOUSE
FLAT
APARTMENT
CARAVAN
HOUSE_BOAT_BERTH
HOUSE_BOAT_NEW_BERTH
SHARED_HOUSE
ACCOMMODATION
Api Model ResultChildOverlay
API Model description of ResultChildOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model ResultParentOverlay
API Model description of ResultParentOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model Rotation
API Enumeration description of Rotation
Name Description
FIXED
QUARTER
FREE
Api Model SWRC
API Enumeration description of SWRC
Name Description
NONE
VAN_GENUCHTEN
Api Model SatelliteOverlay
API Model description of SatelliteOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model Scenario
API Model description of Scenario
description String
events CodedEvent[]
id int
limitNeighborhoodIDs int[] Neighborhood ID
limitType LimitType
name String
restartTestrun boolean
version int
Api Model ScenarioAttribute
API Enumeration description of ScenarioAttribute
Name Description
LIMIT_MARGIN
INDICATORS
Api Model Scope
API Enumeration description of Scope
Name Description
MAP
WATER_AREAS
LIMIT_AREAS
OVERRIDE_RAIN_AREAS
Api Model Section
API Model description of Section
floors int
id int
outerLines MultiLineString
roofHeightM double
roofPolygons GeometryCollection
roofShape float[]
skeletonEnd Point
skeletonLines MultiLineString
skeletonStart Point
slantingRoofHeightM double
Api Model ServiceOverlay
API Model description of ServiceOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
sourceID int Source ID
type OverlayType
version int
visible boolean
warnings String
Api Model ServiceSource
API Model description of ServiceSource
color TColor
date long
description String
format GeoFormat
id int
infoUrl String
name String
uploaderName String
url String
version int
Api Model ShadowAttribute
API Enumeration description of ShadowAttribute
Name Description
DATES
SUN_ALTITUDE
SUN_AZIMUTH
MAX_SHADOW_DISTANCE
MAX_FOLIAGE_RADIUS
Api Model ShadowOverlay
API Model description of ShadowOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model ShadowPrequel
API Enumeration description of ShadowPrequel
Name Description
FOLIAGE_HEIGHT
BUILDING_ELEVATION
TERRAIN_ELEVATION
Api Model ShadowResult
API Enumeration description of ShadowResult
Name Description
SHADE
FOLIAGE
Api Model Shoreline
API Enumeration description of Shoreline
Name Description
NONE
ONE_CELL
TWO_CELLS
Api Model Show
API Enumeration description of Show
Name Description
FAR
MIDDLE
CLOSE
Api Model SightDistanceAttribute
API Enumeration description of SightDistanceAttribute
Name Description
SOURCE_HEIGHT_M
OBSERVER_HEIGHT_M
Api Model SourceOverlay
API Model description of SourceOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
restColor TColor
sortIndex int
sources Map<int,int>
type OverlayType
version int
visible boolean
Api Model SpecialEffect
API Model description of SpecialEffect
active boolean
id int
name String
point Point
version int
Api Model SpecialOption
API Model description of SpecialOption
defaults Type[]
description String
id int
imageName String
name String
version int
Api Model Stakeholder
API Model description of Stakeholder
active boolean
client ClientData
color TColor
id int
imageName String
imageVersion int
lastSelected long
name String
shortName String
startBudget double
startBudgets Map<int,double>
startCinematics Map<int,int>
startPoint Point
type Type
version int
webToken String
Api Model Style
API Enumeration description of Style
Name Description
INTERPOLATED
NEAREST
ARROW
COLOR
FLOAT32
DIFFERENCE
Api Model SubsidenceAttribute
API Enumeration description of SubsidenceAttribute
Name Description
YEARS
YEARS_PER_TIMEFRAME
START_YEAR
A
B
C
ACTIVE_DRAINAGE_FACTOR
PASSIVE_DRAINAGE_FACTOR
CLIMATE_START_TEMP
CLIMATE_FINAL_TEMP
CLIMATE_START_YEAR
CLIMATE_FINAL_YEAR
CLIMATE_OXIDATION
CLIMATE_SOIL_TEMP_FACTOR
LOW_PASSIVE_DRAINAGE
HI_PASSIVE_DRAINAGE
DEFAULT_PEAT_FRACTION
DEFAULT_TOP_LAYER_THICKNESS
DEFAULT_CLAY_THICKNESS
INUNDATE_LAND_BELOW_WATER_LEVEL
Api Model SubsidenceKey
API Enumeration description of SubsidenceKey
Name Description
WATER_LEVEL
WATER_LEVEL_OUTPUT
CLAY_THICKNESS
INDEXATION
PEAT_FRACTION
TOPLAYER_THICKNESS
SUBSIDENCE
DRAINAGE
HI_GROUND_WATER_LEVEL
LOW_GROUND_WATER_LEVEL
Api Model SubsidenceOverlay
API Model description of SubsidenceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model SubsidencePrequel
API Enumeration description of SubsidencePrequel
Name Description
LOW_GROUND_WATER
HIGH_GROUND_WATER
CLAY_THICKNESS
Api Model SubsidenceResult
API Enumeration description of SubsidenceResult
Name Description
SUBSIDENCE
OXIDATION
SETTLEMENT
LOW_GROUND_WATER
HI_GROUND_WATER
Api Model SurfaceMode
API Enumeration description of SurfaceMode
Name Description
NONE
SHALLOW
AVG_WATERWAY
HYBRID
AVG_TERRAIN
Api Model TColor
API Model description of TColor
Api Model TemplateExcelPanel
API Model description of TemplateExcelPanel
answers Answer[]
attribute String
autoApplied boolean
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
mapLink MapLink
name String
parentID int
point Point
relation Relation
text String
type PanelType
updateTiming Timing
useOwner boolean
version int
warnings String
width double
Api Model TemplateTextPanel
API Model description of TemplateTextPanel
answers Answer[]
attribute String
autoApplied boolean
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
mapLink MapLink
name String
parentID int
point Point
relation Relation
text String
type PanelType
updateTiming Timing
useOwner boolean
version int
warnings String
width double
Api Model Tensor
API Model description of Tensor
dimensions int[]
input boolean
name String
normalize boolean
type DataType
API Model description of TensorLink
coordinate int[]
id int
normalized boolean
prequel String
result String
tensorName String
valueType ValueType
Api Model Terrain
API Model description of Terrain
current MultiPolygon
heightValuesCurrent double[]
heightValuesMaquette double[]
id int
maquette MultiPolygon
name String
showSatellite boolean
typeID int Terrain Type ID
version int
Api Model TerrainAttribute
API Enumeration description of TerrainAttribute
Name Description
ANGLE_OF_REPOSE
WATER_DEPTH_M
BOWEN_RATIO
BUILDABLE
SUBSIDENCE
COLOR
HEAT_EFFECT
LIVABILITY_EFFECT
TERRAIN_MIX
TEXTURE_TYPE
WATER
GROUND_INFILTRATION_MD
HYDRAULIC_CONDUCTIVITY_MD
HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD
VAN_GENUCHTEN_M
ROOT_DEPTH_M
VEGETATION_FRACTION
WATER_STORAGE_PERCENTAGE
WATER_MANNING
WATER_MICRORELIEF_M
WATER_TRANSPIRATION_FACTOR
Api Model TerrainFeature
API Model description of TerrainFeature
id int
this$0 TerrainSpatial
version int
Api Model TerrainSpatial
API Model description of TerrainSpatial
id int
innerHeight double
innerPolygon MultiPolygon
innerPrep PreparedGeometry
measureEditType MeasureEditType
outerPolygon MultiPolygon
outerPrep PreparedGeometry
outerRings LineString[]
relative boolean
terrainTypeID int
Api Model TerrainType
API Model description of TerrainType
code String
groundLayerType Layer
id int
imageName String
name String
parentID int Terrain Type ID
version int
Api Model TextPanel
API Model description of TextPanel
answers Answer[]
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
name String
parentID int
point Point
text String
type PanelType
updateTiming Timing
version int
warnings String
width double
Api Model TimeState
API Enumeration description of TimeState
Name Description
NOTHING
WAITING_FOR_DATE
REQUEST_PLOT_OWNER_APPROVAL
REQUEST_ZONING_APPROVAL
REQUEST_CONSTRUCTION_APPROVAL
CONSTRUCTION_APPROVED
CONSTRUCTION_DENIED
PENDING_CONSTRUCTION
CONSTRUCTING
READY
PENDING_UPGRADE
WAITING_FOR_DEMOLISH_DATE
REQUEST_DEMOLISH_ZONING_APPROVAL
REQUEST_DEMOLISH_APPROVAL
DEMOLISH_APPROVED
DEMOLISH_DENIED
PENDING_DEMOLISHING
DEMOLISHING
DEMOLISH_FINISHED
Api Model Timing
API Enumeration description of Timing
Name Description
BEFORE
AFTER
Api Model TrafficAttribute
API Enumeration description of TrafficAttribute
Name Description
HOURS
CARS_ACTIVE
VANS_ACTIVE
TRUCKS_ACTIVE
BUSES_ACTIVE
Api Model TrafficDensityOverlay
API Model description of TrafficDensityOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model TrafficNO2Attribute
API Enumeration description of TrafficNO2Attribute
Name Description
BASE_O3
BASE_NO2
EMISSION_CAR_NOX
EMISSION_CAR_NO2
EMISSION_JAM_CAR_NOX
EMISSION_JAM_CAR_NO2
EMISSION_VAN_NOX
EMISSION_VAN_NO2
EMISSION_JAM_VAN_NOX
EMISSION_JAM_VAN_NO2
EMISSION_TRUCK_NOX
EMISSION_TRUCK_NO2
EMISSION_JAM_TRUCK_NOX
EMISSION_JAM_TRUCK_NO2
EMISSION_BUS_NOX
EMISSION_BUS_NO2
EMISSION_JAM_BUS_NOX
EMISSION_JAM_BUS_NO2
ROAD1_30M_A
ROAD1_30M_B
ROAD1_30M_C
ROAD1_60M_ALPHA
ROAD1_60M_POWER
MIN_TREE_HEIGHT_M
Api Model TrafficNoiseAttribute
API Enumeration description of TrafficNoiseAttribute
Name Description
BACKGROUND_DB
V0_CAR
V0_VAN
V0_TRUCK
V0_BUS
EMISSION_START_CAR
EMISSION_START_VAN
EMISSION_START_TRUCK
EMISSION_START_BUS
EMISSION_MULT_CAR
EMISSION_MULT_VAN
EMISSION_MULT_TRUCK
EMISSION_MULT_BUS
Api Model TrafficOverlay
API Model description of TrafficOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model TrafficType
API Enumeration description of TrafficType
Name Description
CAR
VAN
TRUCK
BUS
BICYCLE
PEDESTRIAN
SHIP
TRAM
TRAIN
AIR
Api Model TravelDistanceAttribute
API Enumeration description of TravelDistanceAttribute
Name Description
MAX_TRAVEL_DISTANCE
ROAD_DISTANCE
ROUTE_PEDESTRIANS
ROUTE_BICYCLES
ROUTE_CARS
ROUTE_TRUCKS
ROUTE_TRAMS
ROUTE_TRAINS
ROUTE_SHIPS
DESTINATION_THRESHOLD
BLOCKING_THRESHOLD
TRAVERSABLE_THRESHOLD
Api Model TravelDistanceKey
API Enumeration description of TravelDistanceKey
Name Description
DESTINATION_AREA
BLOCKED
Api Model TravelDistanceOverlay
API Model description of TravelDistanceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model TravelDistancePrequel
API Enumeration description of TravelDistancePrequel
Name Description
TRAVERSABLE
BLOCKING
DESTINATION
Api Model TravelDistanceResult
API Enumeration description of TravelDistanceResult
Name Description
DESTINATIONS
BASE_TYPES
Api Model Trigger
API Model description of Trigger
active boolean
calcTimeMS long
id int
method Method
name String
timeoutMS int
timing Timing
type Type
url String
version int
warnings String
Api Model Type (PopupData)
API Enumeration description of Type
Name Description
STAKEHOLDER_STANDARD
INTERACTION
INTERACTION_WITH_DATE
INFORMATION
LABEL
Api Model Type (SpecialOption)
Name Description
BUY_LAND
SELL_LAND
DEMOLISH
REVERT
DEMOLISH_UNDERGROUND
RAISE_LAND
SHOW_BUDGETPANEL
SHOW_MONEY_TRANSFER_PANEL
LOWER_LAND
Api Model Type (Stakeholder)
Name Description
CIVILIAN
COMPANY
EDUCATION
EXPERT
FARMER
HEALTHCARE
HOUSING_CORPORATION
MUNICIPALITY
MEDIA
PROJECT_DEVELOPER
UTILITY_CORPORATION
WATER_AUTHORITY
OTHER_AUTHORITY
OTHER
Api Model Type (Trigger)
Name Description
TQL
EVENT
Api Model UniqueNamedItem
API Model description of UniqueNamedItem
id int
name String
version int
Api Model UnitData
API Model description of UnitData
active boolean
colors TColor[]
fileName String
id int
isAlpha boolean
name String
proximityWarningM double
regions Region[]
type TrafficType
version int
Api Model UnitDataOverride
API Model description of UnitDataOverride
active Boolean
colors TColor[]
id int
name String
version int
Api Model UpgradeFeature
API Model description of UpgradeFeature
id int
version int
Api Model UpgradeSpatial
API Model description of UpgradeSpatial
id int
Api Model ValueType
API Enumeration description of ValueType
Name Description
DEFAULT
R
G
B
A
Api Model WCSOverlay
API Model description of WCSOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WCSResult
API Enumeration description of WCSResult
Name Description
NEAREST
INTERPOLATED
Api Model WMSOverlay
API Model description of WMSOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WMSResult
API Enumeration description of WMSResult
Name Description
COLOR
FLOAT32
RED
GREEN
BLUE
ALPHA
Api Model WWOverlay
API Model description of WWOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
type OverlayType
version int
visible boolean
Api Model WaterKey
API Enumeration description of WaterKey
Name Description
WATER_LEVEL
WATER_RELATIVE
INLET_Q
INLET_CAPACITY
INLET_AREA
LOWER_THRESHOLD
UPPER_THRESHOLD
UNDERGROUND
INUNDATION_LEVEL
AQUIFER_KD
AQUIFER_DATUM
SEWER_STORAGE
SEWER_PUMP_SPEED
WEIR_HEIGHT
WEIR_WIDTH
WEIR_COEFFICIENT
WEIR_N
WEIR_ANGLE
WEIR_TARGET_LEVEL
CULVERT_DIAMETER
CULVERT_N
CULVERT_THRESHOLD
CULVERT_RECTANGULAR_HEIGHT
PUMP_Q
PUMP_ANGLE
PUMP_AREA
DRAINAGE_Q
DRAINAGE_DATUM
DRAINAGE_OVERFLOW_THRESHOLD
DRAINAGE_ACTIVE
BREACH_SPEED
BREACH_HEIGHT
BREACH_WIDTH
BREACH_ANGLE
BREACH_COEFFICIENT
BREACH_INPUT_AREA
BREACH_LEVEL_AREA
EXTERNAL_SURFACE_LEVEL
EXTERNAL_WATER_LEVEL
EXTERNAL_AREA
SEWER_OVERFLOW
SEWER_OVERFLOW_SPEED
OBJECT_FLOW_OUTPUT
OBJECT_DATUM_OUTPUT_A
OBJECT_DATUM_OUTPUT_B
OBJECT_WIDTH_OUTPUT
OBJECT_HEIGHT_OUTPUT
OBJECT_WATER_AREA_OUTPUT
WEIR_DAM_OUTPUT
TRACER_A
TRACER_B
TRACER_C
TRACER_D
LIMIT_AREA
RAIN_M
Api Model WaterModelAttribute
API Enumeration description of WaterModelAttribute
Name Description
ALLOWED_WATER_INCREASE_M
GROUND_WATERTABLE_WITH_SURFACE
DESIGN_FLOOD_ELEVATION_M
GROUND_BOTTOM_DISTANCE_M
GROUND_BOTTOM_PRESSURE_M
GROUND_WATER
GROUND_WATER_DEPTH_M
SOIL_WATER_RETENTION_CURVE
UNSATURATED_FRACTION
IMPACT_FLOOD_THRESHOLD_M
IMPACT_RANGE_M
CULVERT_DEM_THRESHOLD_M
QCELL
INCREASED_RESOLUTION
SHORELINE
OBJECT_ENTRY_CORRECTION
SEWER_OVERFLOW_THRESHOLD
DURATION_MIN_LEVEL_M
RISE_RATE_DISTANCE_M
SURFACE_WATER_EVAPORATION_FACTOR
TIMEFRAMES
TIMEFRAME_TIMES
LIMIT_AREA
LIMIT_RAIN
MAX_WATER_BOTTOM_M
START_DATE_MS
AVG_SHORE_WIDTH_M
AVG_TERRAIN_WIDTH_M
AVG_TERRAIN_STORAGE_M
SURFACE_WATER
PREQUEL_SURFACE_LEVEL_RELATIVE
MICRORELIEF_STORAGE_FRACTION
MIN_MAX_ELEVATION
BRIDGE_ELEVATION
MAX_INFILTRATION_M
MIN_DRAIN_SURFACE_DISTANCE_M
INFILTRATION_FACTOR_S
WEIR_DAM_MULTIPLIER
WEIR_DAM_SURPLUS_HEIGHT_M
BREACH_MEASUREMENT_DISTANCE_M
STABILIZER_ANGLE
WEIR_MOVE_INTERVAL_S
WEIR_MOVE_STEP_M
WEIR_MOVE_RANGE_M
PARTIAL_START_SEC
PARTIAL_END_SEC
TRIM_MANNING
TRIM_EVAPOTRANSPIRATION
TRIM_ROOT_DEPTH
TRIM_GROUND_INFILTRATION
TRIM_GROUND_CONDUCTIVITY
TRIM_SHORELINE_CONDUCTIVITY
TRIM_GROUND_STORAGE_FRACTION
Api Model WaterOverlay
API Model description of WaterOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WaterPrequel
API Enumeration description of WaterPrequel
Name Description
TERRAIN_ELEVATION
SURFACE_LEVEL
SURFACE_U
SURFACE_V
SURFACE_INFILTRATION
GROUND_WATER_DEPTH
GROUND_WATER_DATUM
GROUND_CONDUCTIVITY
GROUND_INFILTRATION
BOTTOM_DISTANCE
BOTTOM_RESISTANCE
BOTTOM_PRESSURE
MAX_INFILTRATION
MANNING
MICRORELIEF
SEWER_LEVEL
Api Model WaterResult
API Enumeration description of WaterResult
Name Description
WATER_STRESS
SURFACE_LAST_DIRECTION
SURFACE_AVG_DIRECTION
SURFACE_DURATION
SURFACE_ELEVATION
SURFACE_FLOW
SURFACE_LAST_FLOW
SURFACE_LAST_SPEED
SURFACE_LAST_VALUE
SURFACE_LAST_DATUM
SURFACE_MAX_SPEED
SURFACE_MAX_VALUE
SURFACE_EVAPORATION
SURFACE_LAST_EVAPORATION
BUILDING_LAST_STORAGE
FLOOD_ARRIVAL_TIME
FLOOD_RISE_RATE
LAST_RAIN
RAIN
GROUND_LAST_STORAGE
GROUND_LAST_VALUE
GROUND_LAST_DIRECTION
GROUND_FLOW
GROUND_MAX_STORAGE
GROUND_MAX_VALUE
GROUND_WATERTABLE
GROUND_BOTTOM_FLOW
GROUND_LAST_UNSATURATED_STORAGE
GROUND_LAST_UNSATURATED_FRACTION
GROUND_TRANSPIRATION
GROUND_LAST_TRANSPIRATION
SEWER_LAST_VALUE
SEWER_MAX_VALUE
LAST_EVAPORATED
LAST_EVAPOTRANSPIRATION
EVAPORATED
EVAPOTRANSPIRATION
IMPACTED_BUILDINGS
TRACER_A
TRACER_B
TRACER_C
TRACER_D
BASE_TYPES
SURFACE_DIFFERENCE
DEBUG_UV
GPU_OVERVIEW
DEBUG_AVG_AREAS
DEBUG_UV_DIRECTION
DEBUG_WATERWAYS
SURFACE_LAST_U
SURFACE_LAST_V
Api Model WaterSystem
API Enumeration description of WaterSystem
Name Description
OBJECTS
AREAS
Api Model WaterType
API Enumeration description of WaterType
Name Description
NONE
WATERWAY
WATERBODY
SEA
Api Model WatershedKey
API Enumeration description of WatershedKey
Name Description
DISCHARGE_AREA
Api Model WatershedModelAttribute
API Enumeration description of WatershedModelAttribute
Name Description
FILL_DISTANCE
DISCHARGE_REMAINING_WATER
CULVERT_FLOW_DIRECTION
MIN_AREA
LIMIT_ROAD
Api Model WatershedOverlay
API Model description of WatershedOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
method DischargeMethod
minValue float[]
name String
resultType String
sortIndex int
type OverlayType
version int
visible boolean
warnings String
Api Model WatershedPrequel
API Enumeration description of WatershedPrequel
Name Description
DIRECTION
Api Model WatershedResult
API Enumeration description of WatershedResult
Name Description
WATERSHEDS
DISCHARGE_AREAS
DIRECTION
BASE_TYPES
Api Model WebPanel
API Model description of WebPanel
answers Answer[]
height double
id int
layoutX double
layoutY double
name String
point Point
type PanelType
url String
version int
width double
Api Model ZipCode
API Model description of ZipCode
color TColor
id int
name String
version int
Api Model Zone
API Model description of Zone
center Point
id int
name String
outline Outline
version int
Api Model ZoneAttribute
API Enumeration description of ZoneAttribute
Name Description
MAX_BUILDING_HEIGHT
MAX_ROOF_GUTTER_HEIGHT
MAX_FLOORS
MIN_FLOORS
AMOUNT_FLOORS
MAX_BUILDING_PCT
MONUMENTAL
Api Model ZoneDistanceAttribute
API Enumeration description of ZoneDistanceAttribute
Name Description
HIT_COUNT
