Ribbon
How does the ribbon relate to the Tygron Engine
The ribbon is located in the top part of the Tygron Editor. It is a tabbed header, which provides access to tools grouped by categories. Those categories are in organized in tabs. This makes tools accessible in a logical way.
Ribbon overview
The ribbon at the top consists of 2 parts, the ribbon header and the ribbon bar.
Ribbon header
The ribbon header
The ribbon header provides access to the File Menu and to the tabs Stakeholders, Indicators, 3D World, Animations, Storyline, Tools and Help. The ribbon header also provides access to the Team Chat Box by clicking on your username, the ability to Sign in with ArcGIS Online and provides access to your project details.
Activating one of the tabs reveals context-sensitive buttons on the ribbon bar.
Tabs and buttons
File:Editor ribbon bar middle.jpg
The ribbon header, with active "Indicators" tab, the ribbon bar with the active "Indicators" Button and several other (inactive) buttons
The ribbon header consists of a number of tabs, which provide access to buttons required to edit your project. The visible buttons are context-sensitive, they depend on the active tab in the ribbon header. The different tabs including buttons will be described below.
Ribbon bar
The ribbon bar
The ribbon bar provides access to the main properties adjustable in the Tygron Engine. The ribbon bar has 3 main functionalities. Starting and stopping the test run, currently active buttons (based on the active tab) and accessing and switching playable stakeholders available in the current project.
Test run
Main article: Test run.
test run Active
Ribbon bar dropdown menu
The ribbon bar dropdown menu
A dropdown menu can be presented when hovering buttons on the ribbon bar. The dropdown menu can be used as a shortcut to access the left-panel, to add items to your project, or can redirect users to the documentation section.
Active tabs
Active tabs are indicated by a blue colored text and the tab appearing on the foreground. Currently the "Indicators" tab is active on the ribbon header, providing access to indicators, function values, function assets and function scores buttons on the ribbon bar.
Active buttons
Active buttons are indicated by a blue background color. Currently the "Indicators" button on the ribbon bar is selected. When active, the button provides access to the properties in the left panel. Selecting a different tab in the ribbon header makes different buttons available.
Right: Playable stakeholders, switching stakeholders, collaborate
The ribbon bar with all playable Stakeholders, the currently selected Stakeholder: "Gemeente" (Municipality), and another occupied stakeholder "Company".
On the far right hand side, the ribbon bar displays all playable stakeholders for the current project. The currently active stakeholder is displayed with a blue background. An occupied stakeholder (selected by another user) is indicated with a gray background. Available stakeholders are displayed with a white background. When a user switches stakeholders, or logs out of the Tygron Engine makes this stakeholder available for selection again.
The stakeholder buttons enable users to switch between stakeholders by pressing the corresponding button. You can only switch to a stakeholder that is not yet selected by another user.
The stakeholder buttons are always visible, independently of the tab currently selected in the ribbon header.
Switching stakeholders
Switching a stakeholder is done by pressing an available stakeholder button (displayed with a white background). Keep in mind that, when switching a stakeholder you will also switch the indicators, budget and actions among others. You will make an identity switch!
How to switch to an available stakeholder:
  1. Hover over an available stakeholder in the ribbon bar.
  2. Press the hovered stakeholder.
Inviting someone to join
Users can also invite others to collaboratively make use of the editor. An invitation can be made by hovering over a stakeholder button and selecting "invite a friend".
How to invite others to collaboratively make use of the editor.:
  1. Hover over an available stakeholder in the ribbon bar, the invite dropdown menu appears
  2. Select "Invite a friend" (below the switch stakeholder text)
  3. The invitation panel will appear
  4. Select a registered person from your organisation or invite someone without an account via email
Ribbon tab overview
This section shows a full overview of available tabs and buttons when using the ribbon bar.
File
Main article: File menu.
File Pane
Stakeholders
Contains the options related to stakeholders: stakeholders, actions, measures and messages.
Indicators
Contains the options related to: indicators, the properties of functions, and their effects on custom indicators. The option recalculate indicators can also be found here.
3D World
Contains all the options with a spatial aspect: constructions, land, zoning, terrains, overlays, dike types and upgrade types.
Animations
Contains all the options with a moving aspect: cinematics, special effects, units, weather, environment.
Storyline
Contains the options with a storyline related aspect: Levels, Timeline, Intro Texts and Interface
Tools
Contains the options with a tool related aspect: Event Bundles, Screenshot, Video, Free Cam, Query Tool and the API Overview
Help
Contains the following help options: Team Chat Box, Community, Contact Support
