Api session event editor parametric
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API api session event editor parametric Events. Parametric editing. {|class=wikitable !Name !Description |- |ADD |Add new Parametric |- |APPEND_ATTRIBUTE |Appended to existing Parametric attribute value |- |DUPLICATE |Duplicate existing Parametric |- |REMOVE |Remove existing...")
Parametric editing.
Name Description
ADD Add new Parametric
APPEND_ATTRIBUTE Appended to existing Parametric attribute value
DUPLICATE Duplicate existing Parametric
REMOVE Remove existing Parametric
REMOVE_ATTRIBUTE Remove attribute from Parametric
SET_ATTRIBUTE Set Parametric attribute value
SET_ATTRIBUTES Set multiple Parametric attribute values
SET_NAME Set new name of existing Parametric
Specific Events:
Name Description
ADD_EXAMPLE Add Example
ADD_PLOT Add Plot
APPLY Apply
GENERATE Generate
REMOVE_PLOT Remove Plot
REMOVE_PLOT_ATTRIBUTES Remove Plot Attributes
SAVE_AS_MEASURE Save As Measure
SET_ALIGNMENT Set Alignment
SET_FUNCTION Set Function
SET_PLOT_ATTRIBUTES Set Plot Attributes
SET_PLOT_FUNCTION Set Plot Function
SET_POLYGONS Set Polygons
