Api session event editor indicator
API api session event editor indicator Events.
Indicator editing.
| Name | Description |
| ADD | Add new Indicator |
| APPEND_ATTRIBUTE | Appended to existing Indicator attribute value |
| DUPLICATE | Duplicate existing Indicator |
| REMOVE | Remove existing Indicator |
| REMOVE_ATTRIBUTE | Remove attribute from Indicator |
| SET_ACTIVE | Set Indicator active |
| SET_ATTRIBUTE | Set Indicator attribute value |
| SET_ATTRIBUTES | Set multiple Indicator attribute values |
| SET_COLOR | Set new color of existing Indicator |
| SET_NAME | Set new name of existing Indicator |
Specific Events:
| EXCEL_MIN_LOG_TIME | Excel Min Log Time |
| EXPORT_DEBUG_EXCEL | Export Debug Excel |
| EXPORT_EXCEL_CALL_TREE | Export Excel Call Tree |
| REMOVE_STAKEHOLDER | Remove Stakeholder |
| SET_ABSOLUTE | Set Absolute |
| SET_DESCRIPTION | Set Description |
| SET_EXCEL | Set Excel |
| SET_IMAGE | Set Image |
| SET_PARENT | Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator. |
| SET_SHORT_NAME | Set Short Name |
| SET_STAKEHOLDER | Set Stakeholder |
| SET_TARGET | Set a target value of an Indicator for a Sceanrio. A target index value is required. |
| SET_UPDATE_TIMING | Set Update Timing |
| SWAP_ORDER | Swap Order |
Deprecated Events:
| DUPLICATE_INDICATOR | Use DUPLICATE instead for alsmost (no stakeholder option) identical result. |
| RESET_INDICATORS | Replaced by editor/update/ |
| RESET_INDICATORS_WITH_ID | Replaced by editor/update_with_id/ |
