Release Notes
Revision as of 10:29, 25 February 2026 by Rudolf@tygron.nl (talk | contribs)
LTS Version 2026
Preview Version 2025
LTS Version 2024
LTS Version 2023
LTS Version 2022
LTS Version 2021
LTS Version 2020
LTS Version 2019
Older Versions
December 24th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.4.4.1 in where some internal changes were made to the software. No functionality changes.
December 20th, 2018
November 30th, 2018
  • Hotfix on Preview server. The Preview engine is updated to Version 2019.2.0.1 in where a few bug fixes were done regarding the Measurement Tool and the Net wizard.
November 29th, 2018
November 23th, 2018
  • Hotfix on LTS server. The LTS engine is updated with some fixes for the Community Hub and the Preview engine is updated to Version 2019.1.1.2 in where a bug is fixed regarding the GPU calculation of the subsidence overlay.
November 13th, 2018
  • Hotfix on LTS server. The LTS engine is updated with a new fix for the Community Hub.
November 12th, 2018
November 9th, 2018
November 9th, 2018
November 2th, 2018
October 26th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.4.3.1 and the Preview engine is update to Version 2019.0.0.10 in where a bug is fixed with the building of dikes and also a small improvement in speed of the project.
October 19th, 2018
October 16th, 2018
  • Hotfix on LTS server. The LTS engine is updated to Version 2018.4.2.5. In this version some bugfixes were done.
October 15th, 2018
  • Hotfix on LTS & Preview server. The LTS engine is updated to Version 2018.4.2.4 and the Preview engine is update to Version 2019.0.0.9. In these versions a bugfix is done.
October 10th, 2018
  • Hotfix on LTS & Preview server. The LTS engine is updated to Version 2018.4.2.3 and the Preview engine is update to Version 2019.0.0.8. In these versions the indicator graph now shows max. 1000 values. If there are more values, they are interpolated and shown in the graph. Also some bugfixes were done.
October 9th, 2018
  • Hotfix on LTS server. The LTS engine is updated to Version 2018.4.2.2. In this version some internal changes were made to the software. No functionality changes.
October 8th, 2018
  • Hotfix on LTS server. The LTS engine is updated to Version 2018.4.2.1. In this version some internal changes were made to the software. No functionality changes.
October 5th, 2018
  • Hotfix on Preview server. The Preview engine is updated to Version 2010.0.0.1. In this version the map ratio for a rectangular project is now set to max 4. Some bugfixes for the Average Overlay Panel and the Save Overlay result were done.
October 1th, 2018
September 28th, 2018
September 12th, 2018
September 2th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.4.1.5. In this version a change in communicating with the API is made.
August 15th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.4.1.2. In this version some changes are made to prevent projects from continuously calculating when a project is already not responding.
August 9th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.4.1.1. In this version some changes are made in the appearance and functioning of the Community Hub.
August 7th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.4.1. In this version some changes are made in the appearance and functioning of the Community Hub.
August 3th, 2018
June 29th, 2018
May 18th, 2018
May 11th, 2018
March 30th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.2.1, in where a bugfix is done with cancelling a planned measure and some changes related to network technology.
March 23th, 2018
March 19th, 2018
March 16th, 2018
March 13th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.15, in where a fix is done for a rounding off error which triggered a continuous loop of calculations (did not occur often).
March 13th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.14, in where changes are made so the AHN is imported faster.
March 9th, 2018
March 5th, 2018
March 2th, 2018
March 1th, 2018
February 26th, 2018
February 16th, 2018
February 9th, 2018
February 6th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.6. In this version a bugfix when deleting a global is made and the performance of large projects is improved.
February 5th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.5. In this version more specific types of graphic drivers are now recognized, to reduce hardware issues.
February 2th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.4. In this version a few bugfixes are made.
January 30th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.2. In this version security updates are done and further some textual fixes.
January 29th, 2018
  • Update on LTS server. The LTS engine is updated to Version 2018.2.0.1. In this version missing images are restored and correct links to the Wiki are provided.
January 26th, 2018
January 11th, 2018
January 10th, 2018
January 9th, 2018
January 5th, 2018
  • New release on LTS server. The LTS engine is updated to Version 2018.1.1.5 in where a bug is fixed for specifying a too large map size via the API.
January 4th, 2018
December 22th, 2017
December 21th, 2017
  • New release on LTS server. The LTS engine is updated to Version 2018.1.1.2 in where there are made some improvements when there is a slow internet connection when creating a project.
December 20th, 2017
  • New release on LTS server. The LTS engine is updated to Version 2018.1.1.1 in where improvements are made so that there is less GPU capacity needed, faster loading of projects and no netwerk time-outs when loading a project.
December 19th, 2017
December 13th, 2017
December 12th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2018.1.0.4 in where a bug is fixed.
December 12th, 2017
December 9th, 2017
December 8th, 2017
December 6th, 2017
November 13th, 2017
  • Update on Preview server. The Preview engine is updated to Version 2018.0.0.2. Further improvements on GPU scheduling and when a calculation takes too long, it is automatically restarted.
November 10th, 2017
  • Update on Preview server. The Preview engine is updated to Version 2018.0.0.1. Improved GPU scheduling and URL encoding.
November 3th, 2017
October 19th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.20. The memory usage is now better evaluated.
October 16th, 2017
September 29th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.17. Sorting for NIF-files is changed to the latest method. Keep alive session in multi-user sessions is now possible. Bug with overlays staying visible in the 2D-viewer is fixed.
September 27th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.16. From now on the neighborhoods and ownership overlays can be permanently deleted from your project. Also it is not possible to add Geotiff data in an empty map project. Also a bug which occurred when deleting a terrain type is fixed.
September 26th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.15. Update of the video card list. The newest video cards are now also recognized by the Engine.
September 22th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.14. Fix for water edges, which are now visualized smoother.
September 21th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.13. Internal better handling of TQL error messages by email. No changes visible for end users.
September 19th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.12. Bug in calculating the sewer storage when importing sewer areas is fixed.
September 18th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.11. Surface terrein is interpolated with AHN2 data which results in more detail in the heightmap in newly created projects. Also a bug fixed in GPU/CUDA error.
September 15th, 2017
  • Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.10. The rasterization of the heightmap is improved. Now more detail in the heightmap is visible.
September 12th, 2017
August 24th, 2017
August 22th, 2017
August 18th, 2017
August 11th, 2017
July 7th, 2017
June 29th, 2017
June 13th, 2017
  • Hotfix on Preview server. GPU connection bug fixed and two missing icons are added.
June 12th, 2017
May 12th, 2017
March 17th, 2017
January 27th, 2017
  • Hotfix on all Tygron servers. Proxy Detector update benificial for corporate networks. Makes it possible to start the Tygron Platform on internal networks now.
January 13th, 2017
December 27th to 30th, 2016
  • Maintenance on all Tygron servers.
December 23th, 2016
December 16th, 2016
  • On the Test server issues fixed. This is part of the latest developments that will becaome available on the preview server in 2017.
December 10th, 2016
December 2th, 2016
November 10th, 2016
  • Hotfix on all Tygron servers. Our SSL certificate is renewed, ensuring secured connections for another 3 years.
October 26th, 2016
  • Hotfix on all Tygron servers. PDOK has new policy, a maximum of 1000 features (in other words, constructions) can be requested from the BAG at once. This new policy resulted in incomplete maps where some constructions where not visible. With this hotfix this problem is resolved and therefor new maps can be loaded where you can see all the constructions again.
October 2th, 2016
September 28th, 2016
September 23th, 2016
September 14th, 2016
June 6th, 2015
  • Beta Server update - Version 2.4.1 has been released, with updates for mapsize, performance improivements and new icons.
April 9th, 2015
  • Beta Server update - We’ve released a new version of our vector-enabled Beta engine. Feel free to request a free trial through our site if you haven’t yet! (UPDATE: this function is no longer available, for more information about this please fill out the contact from on our website)
February 24th, 2015
  • Port your old projects to the new Platform using Porting projects to the new Tygron Platform !
December 3rd, 2014
  • The BioConSepT project has been awarded a CommNet Impact Award!
November 7th, 2014
November 6th, 2014
October 9th, 2014
October 1st, 2014
