Building elevation prequel (Heat Overlay)
Revision as of 14:48, 23 January 2024 by Frank@tygron.nl (talk | contribs)
Name | Prequel | Underlying data | Unit | Range | No data | Description |
Building elevation | BUILDING_ELEVATION | Heat Prequel | m | -10000 to 10000 | Clamped to range | Used for initializing the digital surface model used for this Heat Overlay. |
- The values in this prequel grid are clamped between the mentioned min and max. No data values are not allowed, although negative NO_DATA values will result in a foliage height of 0. An Average Overlay can be used to fill in the NO_DATA values of an other grid overlay.
- The building elevation is a datum height.
