Gridvalue (TQL Param)
Revision as of 10:22, 28 February 2023 by Frank@tygron.nl (talk | contribs) (Created page with "{{Param TQL|suppresscategory=true|allowselflinks=true| <onlyinclude> {{Param TQL|type=row|attribute=STAKEHOLDER|type=Item ID|description=Only include Grid Overlay cells that have a value equal to the one specified|polygon=false|}} </onlyinclude> }} {{article end |notes= * This clause restricts the TQL query polygon * Only use this clause when you need exactly this value. Otherwise, use the other two mentioned below. |seealso= * Mingridvalue (TQL Param) * Maxgr...")
| Param | Type | Description | Limits search polygon |
- This clause restricts the TQL query polygon
- Only use this clause when you need exactly this value. Otherwise, use the other two mentioned below.
