Advanced options (New Project Wizard)
What is the advanced options panel
The advanced options panel in the wizard allows you to make a selection of data sources you want to use for creating your new project. It varies between the option to select or deselect a data source and change some settings like the resolution of data sources.
Where to find the advanced options
Area properties based on public data pertaining the selection (default)
When choosing the location of the project area during the New project Wizard, in the second panel of the wizard, the default mode for data selection is Selection. When this option is checked, the Tygron Platform will acquire datasets from a variety of open datasets that are linked to the selected area. Find an overview on which data is used to create a new 3D model on the Project Sources page. The Advanced Options panel can be found above the selection option. When you open this panel the list of a few of the open datasets is displayed. You can choose to include or excluded specific data sources in your project creation.
Options
A number of options are available.
Datasources
A number of Project Sources can be activated or deactivated
Datatype Source Fallback Effect
Constructions and spatial features BGT BAG The BGT has greater detail than the BAG.
Risk Assesment Risicokaart - Constructions are added and enriched with safety zones when present in the Projects location.
Agriculture BRP - Crop fields, grassland for livestock, and other agrarian fields are loaded in as Cosntructions. Deactivating it will leave most agrarian fields empty.
Waterschapshuis IMWA - Water system Constructions such as Culverts are retrieved from IMWA. Deactivating it will omit Constructions relevant for water systems.
Zoningplan Ruimtelijke plannen - Zoning plans are added to the Project, with restrictions on what kind of Constructions can be placed in what locations. Deactivating it will omit the zoning plan entirely.
Underground BRO - The underground Terrain is based on data from the BRO. Deactivating it will leave the underground entirely unknown.
I3S Scenelayer I3S Scenelayer - Using I3S allows 3D models to be visualized for existing constructions. Otherwise Tygron uses its internal polygon-based Construction visualization technique.
Elevation model AHN3 AHN2 The AHN3 is newer and more accurate than the AHN2. Both serve as direct input for the elevation model.
Enrichments
Datatype Source Effect
Water BGT / BAG When activated, the BGT or BAG are used to add water to the Project. If deactivated, no water is added to the Project.
Ownership BRK Constructions are assigned ownership based on cadastral information combined with default assumptions connected to types of Constructions, and empty land belonging to the local municipality. If deactivated, all land will belong to the local municipality.
Examples of advanced options
Advanced options panel (default)
