How to add an Attribute to a Function
Revision as of 12:00, 11 June 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "While each Function in the {{sfotware}} already has a large amount of Function Values, the values available by default do not neccesarily define all aspects of Construct...")
While each Function in the Template:Sfotware already has a large amount of Function Values, the values available by default do not neccesarily define all aspects of Constructions you may be interested for your own calculations. It is possible to add user-defined Attributes to any Function, which behave very similarly to built in Function Values.
Template:Editor steps
