How to model drainage (Water Overlay)
Revision as of 10:56, 10 June 2020 by Rudolf@tygron.nl (talk | contribs)
When using the Water Overlay to calculate groundwater model (Water Overlay) situations, the presence of drainages can have a strong impact on the results. Currently, drainages are not an available hydraulic structure. Instead, the effects of drainages can be approximated using Aquifers, configured with a low resistance and set to the height of the drainages.
Manually adding a drainage
Note that these steps assume the Overlay Keys are set to the default Attributes.
How to manually create a drainage-approximating aquifer:
Preparing and importing drainage data
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → your Water Overlay (Left panel) → Configuration Wizard (Right panel)
How to prepare and load in drainage data:
- Ensure your geographic data set has polygons indicating the locations of drainages.
- Ensure that the data has attributes indicating an (excessively) high flow-through value.
- Ensure that the data has attributes indicating at what height relative to datum the drainages are situated.
- Export the data as GeoJSON.
- Open the Water Overlay Wizard, and continue to the step for aquifers.
- Opt to import new data, and import your drainages file.
