Surface infiltration formula (Water Overlay)
Revision as of 07:40, 17 October 2019 by Frank@tygron.nl (talk | contribs)
First, the infiltration capacities are calculated:
Cwater = Wsurface
Ctop = max( Icon, Isurf )
Then the actual infiltration:
Δw = min( Cwater , Δt * Ctop)
Where:
  • Failed to parse (unknown function "\deltat"): {\displaystyle \deltat} = Computational timestep.
  • Ctop = The amount of infiltration that can take place based on the infiltration values present.
Related
Surface water level formula
Groundwater level formula
Models
Surface model
Underground model
Infiltration model
Substance flow model
Template:WaterOverlay nav
