Evapotranspiration model (Water Overlay)
Water can evaporate from the hydrological model over time. Multiple forms of evaporation are implemented, namely surface and underground evaporation.
Both forms of evaporation can be configured directly by setting the weather's evaporation rate. If the evaporation rate is set to 0, no evaporation will take place in any form.
The weather's evaporation rate is defined as a period during which a certain rate of evaporation will take place, similar to rainfall. Multiple periods of evaporation can be defined, and at any specific moment during the simulation an exact evaporation rate is defined by the weather.
Per form of evaporation, the weather's evaporation rate is used as a base for determining the exact amount of evaporation per timestep.
Surface evaporation model
Water situated on the surface is conceptually able to evaporate. The amount is based on the weather's evaporation factor and the overlay's SURFACE_WATER_EVAPORATION_FACTOR. These two multiplied result in a evaporation amount per second, which is calculated for each grid cell individually.
Underground evaporation model
Conceptually, water can evaporate from the underground via crops and foliage. These can draw water from the unsaturated and saturated zones in the underground, if their roots reach deep enough and the terrain or construction have a positive evaporation factor. Water is drawn from the underground and evaporated into the air, effectively removing it from the hydrological model. Water for evaporation can only be drawn from sections of the underground which are within the root depth.
The underground evaporation can be configured directly by changing the terrain type's WATER_EVAPORATION_FACTOR and construction 's WATER_EVAPORATION_FACTOR. If these attributes are set to 0, no underground evaporation will take place.
Similar to the surface evaporation, the rate of underground evaporation is also determined by the weather's evaporation rate.
Again, the amount of evaporation per timestep is WATER_EVAPORATION_FACTOR x WEATHER_EVAPORATION_RATE.
Underground evaporation first draws water from the saturated region and then from the unsaturated region. The sum of these two with be no larger than WATER_EVAPORATION_FACTOR x WEATHER_EVAPORATION_RATE.
Related models
- Surface evaporation only uses one factor: the overlay's SURFACE_WATER_EVAPORATION_FACTOR.
- Zero evaporation is allowed, but negative is not.
- Underground evaporation will not take place when the Underground model is not active.
