Water Overlay Wizard
Flooding Wizard Introduction Page
The configuration wizard is a special interface which helps to guide the configuration of the overlay. Across multiple steps, it progresses through each type of Data which can be configured, along with the most important attributes of the overlay.
Template:Editor ribbon
Step 1: Weather
Step 1: Weather event
Step 2: Water system
Step 2: Setup Water System
The water system is the most complex step of the configuration and contains a multitude of substeps to configure all geographical data. Its various components can be configured in the following order:
Breach (flooding overlays only): A breach area, a location where an (uncontrolled) inflow of water takes places.
Water areas: Water level areas, defined regions in which a specific water level is maintained. It is also possible to have the wizard generate a single water level area for the entire project area.
Ground water: Ground water, the height of the underground saturated by water relative to datum. A GeoTIFF can be imported.
Sewers: Sewer areas, the broad definitions for where what kind of sewers exist. It is also possible to have the wizard generate sewer areas based on the neighborhoods in the project area.
Inundation areas: Inundation areas, definitions of water on the surface, in the form of inundated land. It is also possible to have the wizard generate a single inundation area covering the entire project area.
Aquifer areas (groundwater overlays only): Aquifer areas, definitions for transmissivity or hydraulic conductivity of the underground layer.
Weirs: Weirs, minor barriers in the water flow.
Culverts: Culverts, tunnels which form direct connections between two locations.
Pumps: Pumps, structures which move water from a lower to a higher location.
Inlets: Inlets, structures which add or remove water.
Sewer overflows: Sewer overflows, points where water from sewers can flow back onto the surface.
All of the above components can be imported or connected to the hydrological model.
Step 4: Interaction
Step 5: Output overlays
Multiple result types are available. In the wizard multiple result types can be selected. One result type (indicated with the "First" checkbox) will be the main overlay's result type. The other selections will become result child overlays. Relevant attributes can be modified as well, if they are related to selected result types.
Step 6: Input overlays
To gain more insight into the data used by the model, you may opt to add one or more input overlays as well. These add Average Overlays configured for the geographical display of attribute values relevant for the calculation of the water model.
