Hydrological attributes of terrains (Water Overlay)
Revision as of 13:17, 3 April 2019 by Frank@tygron.nl (talk | contribs)
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a construction is present with overwriting values.
| WATER_STORAGE_PERCENTAGE | fraction | Underground | The percentage (as a fraction) of the underground volume which can be filled with water. A lower percentage means the underground will be able to store less water, and the saturated zone will rise higher with the same amount of water in the underground layer. |
| WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the construction. |
| SUBSTANCE_A | x/m²s | The amount of substance A created per second per m² in this location. | |
| SUBSTANCE_B | x/m²s | The amount of substance B created per second per m² in this location. | |
| SUBSTANCE_C | x/m²s | The amount of substance C created per second per m² in this location. | |
| SUBSTANCE_D | x/m²s | The amount of substance D created per second per m² in this location. |
