Release Notes
January 4th, 2019
- Hotfix on LTS server. The LTS engine is updated to Version 2018.4.4.2 in where a small improvement in the API is made.
December 24th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.4.1 in where In this version some internal changes were made to the software. No functionality changes.
December 20th, 2018
- Update on Preview server. The Preview engine is updated to Version 2019.3.0.1
November 30th, 2018
- Hotfix on Preview server. The Preview engine is updated to Version 2019.2.0.1 in where a few bug fixes were done regarding the Measurement Tool and the Net wizard.
November 29th, 2018
- Update on Preview server. The Preview engine is updated to Version 2019.2.0
November 23th, 2018
- Hotfix on LTS server. The LTS engine is updated with some fixes for the Community Hub and the Preview engine is updated to Version 2019.1.1.2 in where a bug is fixed regarding the subsidence overlay and GPU calculation.
November 13th, 2018
- Hotfix on LTS server. The LTS engine is updated with a new fix for the Community Hub.
November 12th, 2018
- Update on Preview server. The Preview engine is updated to Version 2019.1.1.1
November 9th, 2018
November 9th, 2018
- Update on Preview server. The Preview engine is updated to Version 2018.1.1
November 2th, 2018
- Update on Preview server. The Preview engine is updated to Version 2019.1.0
October 26th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.3.1 and the Preview engine is update to Version 2019.0.0.10 in where a bug is fixed with the building of dikes and also a small improvement in speed of the project.
October 19th, 2018
October 16th, 2018
- Hotfix on LTS server. The LTS engine is updated to Version 2018.4.2.5. In this version some bugfixes were done.
October 15th, 2018
- Hotfix on LTS & Preview server. The LTS engine is updated to Version 2018.4.2.4 and the Preview engine is update to Version 2019.0.0.9. In these versions a bugfix is done.
October 10th, 2018
- Hotfix on LTS & Preview server. The LTS engine is updated to Version 2018.4.2.3 and the Preview engine is update to Version 2019.0.0.8. In these versions the indicator graph now shows max. 1000 values. If there are more values, they are interpolated and shown in the graph. Also some bugfixes were done.
October 9th, 2018
- Hotfix on LTS server. The LTS engine is updated to Version 2018.4.2.2. In this version some internal changes were made to the software. No functionality changes.
October 8th, 2018
- Hotfix on LTS server. The LTS engine is updated to Version 2018.4.2.1. In this version some internal changes were made to the software. No functionality changes.
October 5th, 2018
- Hotfix on Preview server. The Preview engine is updated to Version 2010.0.0.1. In this version the map ratio for a rectangular project is now set to max 4. Some bugfixes for the Average Overlay Panel and the Save Overlay result were done.
October 1th, 2018
- Update on Preview server. The Preview engine is updated to Version 2019.0.0.
September 28th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.2.
September 12th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.1.6.
September 2th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.1.5. In this version a change in communicating with the API is made.
August 15th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.1.2. In this version some changes are made to prevent projects from continuously calculating when a project is already not responding.
August 9th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.1.1. In this version some changes are made in the appearance and functioning of the Community Hub.
August 7th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.1. In this version some changes are made in the appearance and functioning of the Community Hub.
August 3th, 2018
June 29th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.4.0.
May 18th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.3.0.2.
May 11th, 2018
March 30th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.2.1, in where a bugfix is done with cancelling a planned measure and some changes related to network technology.
March 23th, 2018
March 19th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.1.0.
March 16th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.16.
March 13th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.15, in where a fix is done for a rounding off error which triggered a continuous loop of calculations (did not occur often).
March 13th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.14, in where changes are made so the AHN is imported faster.
March 9th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.13.
March 5th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.12.
March 2th, 2018
- Hotfix on LTS server. The LTS engine is updated to Version 2018.2.0.11.
March 1th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.10.
February 26th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.9.
February 16th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.8.
February 9th, 2018
- Hotfix on LTS server. The LTS engine is updated to Version 2018.2.0.7.
February 6th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.6. In this version a bugfix when deleting a global is made and the performance of large projects is improved.
February 5th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.5. In this version more specific types of graphic drivers are now recognized, to reduce hardware issues.
February 2th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.4. In this version a few bugfixes are made.
January 30th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.2. In this version security updates are done and further some textual fixes.
January 29th, 2018
- Update on LTS server. The LTS engine is updated to Version 2018.2.0.1. In this version missing images are restored and correct links to the Wiki are provided.
January 26th, 2018
- New release on LTS server. The LTS engine is updated to Version 2018.2.0.0.
January 11th, 2018
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.8.
January 10th, 2018
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.7.
January 9th, 2018
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.6.
January 5th, 2018
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.5 in where a bug is fixed for specifying a too large map size via the API.
January 4th, 2018
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.4.
December 22th, 2017
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.3.
December 21th, 2017
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.2 in where there are made some improvements when there is a slow internet connection when creating a project.
December 20th, 2017
- New release on LTS server. The LTS engine is updated to Version 2018.1.1.1 in where improvements are made so that there is less GPU capacity needed, faster loading of projects and no netwerk time-outs when loading a project.
December 19th, 2017
December 13th, 2017
- New release on Preview server. The Preview engine is updated to Version 2018.1.0.5.
December 12th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2018.1.0.4 in where a bug is fixed.
December 12th, 2017
- New release on Preview server. The Preview engine is updated to Version 2018.1.0.3.
December 9th, 2017
- New release on Preview server. The Preview engine is updated to Version 2018.1.0.2.
December 8th, 2017
- New release on Preview server. The Preview engine is updated to Version 2018.1.0.1.
December 6th, 2017
- New release on Preview server. The Preview engine is updated to Version 2018.1.0.0.
November 13th, 2017
- Update on Preview server. The Preview engine is updated to Version 2018.0.0.2. Further improvements on GPU scheduling and when a calculation takes too long, it is automatically restarted.
November 10th, 2017
- Update on Preview server. The Preview engine is updated to Version 2018.0.0.1. Improved GPU scheduling and URL encoding.
November 3th, 2017
- New release on Preview server. The Preview engine is updated to Version 2018.0.0.0.
October 19th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.20. The memory usage is now better evaluated.
October 16th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.19.
September 29th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.17. Sorting for NIF-files is changed to the latest method. Keep alive session in multi-user sessions is now possible. Bug with overlays staying visible in the 2D-viewer is fixed.
September 27th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.16. From now on the neighborhoods and ownership overlays can be permanently deleted from your project. Also it is not possible to add Geotiff data in an empty map project. Also a bug which occurred when deleting a terrain type is fixed.
September 26th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.15. Update of the video card list. The newest video cards are now also recognized by the Engine.
September 22th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.14. Fix for water edges, which are now visualized smoother.
September 21th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.13. Internal better handling of TQL error messages by email. No changes visible for end users.
September 19th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.12. Bug in calculating the sewer storage when importing sewer areas is fixed.
September 18th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.11. Surface terrein is interpolated with AHN2 data which results in more detail in the heightmap in newly created projects. Also a bug fixed in GPU/CUDA error.
September 15th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.10. The rasterization of the heightmap is improved. Now more detail in the heightmap is visible.
September 12th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.9.
August 24th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.2.
August 22th, 2017
- Hotfix on Preview server. The Preview engine is updated to Version 2017.5.1.1.
August 18th, 2017
- The Preview Engine is updated to Version 2017.5.1.
August 11th, 2017
- The Preview Engine is updated to Version 2017.5.0.
July 7th, 2017
- The Preview Engine is updated to Version 2017.4.1.
June 29th, 2017
- The Preview Engine is updated to Version 2017.4.0.
June 13th, 2017
- Hotfix on Preview server. GPU connection bug fixed and two missing icons are added.
June 12th, 2017
- The Preview Engine is updated to Version 2017.3.1.
May 12th, 2017
- The Preview Engine is updated to Version 2017.3.0.
March 17th, 2017
- The Preview Engine is updated to Version 2017.2.0.
January 27th, 2017
- Hotfix on all Tygron servers. Proxy Detector update benificial for corporate networks. Makes it possible to start the Tygron Platform on internal networks now.
January 13th, 2017
- Small update on the Preview Server to Version 2017.1.1.
December 27th to 30th, 2016
- Maintenance on all Tygron servers.
December 23th, 2016
- The Preview engine is updated to Version 2017.1.0.
December 16th, 2016
- On the Test server issues fixed. This is part of the latest developments that will becaome available on the preview server in 2017.
December 10th, 2016
- The LTS engine is updated to Version 2017.0.7.
December 2th, 2016
- The Preview engine is updated to Version 2017.0.6.
November 10th, 2016
- Hotfix on all Tygron servers. Our SSL certificate is renewed, ensuring secured connections for another 3 years.
October 26th, 2016
- Hotfix on all Tygron servers. PDOK has new policy, a maximum of 1000 features (in other words, constructions) can be requested from the BAG at once. This new policy resulted in incomplete maps where some constructions where not visible. With this hotfix this problem is resolved and therefor new maps can be loaded where you can see all the constructions again.
October 2th, 2016
- The engine is updated to Version 2017.0.5.
September 28th, 2016
- The engine is updated to Version 2017.0.4.
September 23th, 2016
- The engine is updated to Version 2017.0.3.
September 14th, 2016
- The engine is updated to Version 2017.0.2.
June 6th, 2015
- Beta Server update - Version 2.4.1 has been released, with updates for mapsize, performance improivements and new icons.
April 9th, 2015
- Beta Server update - We’ve released a new version of our vector-enabled Beta engine. Feel free to request a free trial through our site if you haven’t yet! (UPDATE: this function is no longer available, for more information about this please fill out the contact from on our website)
February 24th, 2015
- Port your old projects to the new Platform using Porting projects to the new Tygron Platform !
December 3rd, 2014
- The BioConSepT project has been awarded a CommNet Impact Award!
November 7th, 2014
- Version 2.0 will go beta in January 2015!
November 6th, 2014
- The engine is updated to Version 1.4.2.
October 9th, 2014
- The engine runs on the new Oculus Rift DK2.
October 1st, 2014
- The engine is updated to a new version: Release Notes 01-10-2014.
