Account management
(Redirected from User Account)
User account management is the process that focuses on the administration of users of IT and information systems. This process manages the registration of users and the authorization of their roles within the Tygron Platform. Authorized access is secured with a user specific login name and password.
Each user always belongs to one domain. Therefore, there are two types of user account management.
  1. An existing user can manage it's own user account.
  2. Every domain needs to have at least one Domain Admin who can manage the domain. This Domain Admin is also a user.
Examples of User Management options are:
  • Configuring which projects and project versions a user can access
  • Whether access to that project is read-only
  • Whether a user can update his credentials (login, password)
  • Whether a user can save changes made to a project;
  • Whether a user can host or join a session with other users
Different account types
The following account types can be assigned to a user by a Domain Admin to limit what a user can do within the domain:
Access level Description Available options
in main menu
JOIN ONLY This account can only join, or be invited to a hosted session Join only
HOST SESSION In addition to joining sessions, this account can start single and multiplayer sessions and invite others. Host Session
EDITOR Besides hosting and participating in sessions, this account type can create and edit its own projects. Editor
DOMAIN ADMIN This account is the highest access level available. With this account you can also manage other accounts from your user domain. Domain Admin
Managing the Security Policy for a Domain
Within a domain it is possible for the Domain Admin to set up specific Security Options (access via the startup Options menu).
Security Options, available under Options in the Main Menu (Domain Admins only)
Two-Factor Verification
Two-Factor Verification requires users to enter a security code sent via text message during login. This setting is enabled for the selected account type and up. If it is enabled for the Editor Account type, the verification is also required for the Domain Admin account. Please note that entering phone numbers for users is required for this option.
Minimal Password Length
This option lets the Domain Admin select the minimal number of characters required for a user password set by the user, or by password resets.
Login key expiration
This option lets the Domain Admin select how long a user can remain logged in before they need to re-enter their password.
Support for GeoShare
This option gives access to Tygron support employees to edit files on the GeoShare. It is disabled by default.
Log Retention Periods
This option determines how long logs are retained before they’re automatically deleted. The default retention period is five years (60 months), but it can be adjusted for each log type. For example, user login logs can be kept for a shorter period than session logs, depending on your organization’s policy.
