UK Benchmark 1 (Water Module)
This benchmark performs test case 1 of the UK benchmark [1] named Test 1 – Uncovering of a beach as well as its result generated by the Water Module in the Tygron Platform.
This test consists of a sloping topography with a depression. An inflow boundary condition is applied at the low end, causing the water to rise to the level indicated by a thick blue line. The inflow is then replaced by a sink term until the water level becomes as indicated by the thin blue line. A similar test has been used by EDF (2000) for validation of the TELEMAC package. The aim of the test is to assess basic package capabilities such as handling disconnected water bodies and wetting and drying of floodplains.
Description
Fig. a: Sloping topography with depression
This test consists of a sloping topography with a depression as illustrated in Figure (a). The modeled domain is a perfect 700m x 100m rectangle. A varying water level over time, see Figures (b) and (c), is applied as a boundary condition along the entire length of the left-hand side of the rectangle, causing the water to rise to level 10.35m. This elevation is maintained for long enough for the water to fill the depression and become horizontal over the entire domain. It is then lowered back to its initial state, causing the water level in the pond to become horizontal at the same elevation as the sill, 10.25m.
Fig. b: Top down situation
Fig. c: Water level rise at the left boundary
  • Varying water level along the dashed red line in Figure (a). Table provided as part of dataset.
  • All other boundaries are closed.
  • Initial condition: Water level elevation = 9.7m.
Parameter values
  • Manning’s n: 0.03 (uniform)
  • Model grid resolution: 10m (or 700 nodes in the area modeled)
  • Simulation end time: 20 hours
Technical setup
Heightmap
The provided ascii height file named test1DEM.asc is first imported. It has a cell size of 2m, while the test is expected to run on a 10m grid. Therefore, it will be automatically rescaled by the Rasterization process. The resulting rescaled asc file is packed in the down below.
Overlay settings
General parameters that have been used:
  • Type of overlay: Flooding Overlay
  • Weather:
    • Evaporation: 0 mm
    • Rain: 0 mm
    • Simulate for: 20 hours.
  • Groundwater: 0 (off)
  • Calculation mode: Accuracy
  • Quad cell: 0
Inlets
In order to regulate the water level according to the water level graph, we used the following setup: On gridcells with x = 1 and x = 2 Inlet objects were placed. Each inlet had its own grid cell. The inlets were configured as:
  • External area (m2): 1 000 000 000;
  • Water level (m): 1.0;
  • Inlet Q (m3/s):
time (hrs) inlet Q (m3/s)
0, 1000
11 1000
11 + 1 sec -1000
22 -1000
  • Threshold (m): dynamic;
The threshold array was set using a .csv file to approximate the water level over time without linear interpolation. This setup provided results consistent with the benchmark requirements. The inletthresholds.csv-file can be found in the zip-file below.
Output as required
  • Software package used: Tygron Platform
  • Numerical scheme: FV (Kurganov, Bollermann, Horvath)*
  • Specification of hardware used to undertake the simulation:
    • Processor: Intel Xeon @2.10GHz x 8,
    • RAM 62.8 GiB,
    • GPU: 2x NVidia 1080
    • Operating system: Linux 4.13
  • Time increment used: adaptive: 0.25 - 1.13 s.
  • Grid resolution: 10 m.
  • Simulation time: 28s.
  • Remaining volume water: 10050 m3
  • Graph of point 1 generated by the Tygron Platform on the left and generated by others on the right.
  • Graph of point 2 generated by the Tygron Platform on the left and generated by others on the right.
  • Slice of the situation in the x -direction, generated by the Tygron Platform.
  • Tests use a multi-GPU setup; however, for small cases, a single GPU is faster (17s), roughly 40% faster than using two.
  1. ↑ Benchmarking the latest generation of 2D hydraulic modelling packages. Report: SC120002 ∙ Néelz, S., & Pender, G. (2013) ∙ Environment Agency, Horison House, Deanery Road, Bristol, BS1 9AH. ISBN: 978-1-84911-306-9 ∙ Found at: https://www.gov.uk/government/publications/benchmarking-the-latest-generation-of-2d-hydraulic-flood-modelling-packages ∙ (last visited: 2026-02-25)
