How to remove a Panel
The left panel for panels in the editor with the remove button highlighted.
Panels can be removed from a Project.
Editor → Current Situation (Ribbon tab) → Panels (Ribbon bar) → The Panel to edit (Left panel)
How to remove a Panel:
  1. Open the list of Panels.
  2. Open the "Single Panels" listing.
  3. In the left panel, select the panel to remove.
  4. At the bottom of the left panel, select "Remove".
  5. The Panel is now removed from the Project.
  • To remove instances of a Template Panel, comparable steps can be taken. However, in those cases it is recommended to reconfigure the Template Panel's filter so that the superfluous instances are not created when the
Template Panel is reapplied.
API Endpoints
