How to open the Project Sources panel
How to show the project sources panel:
  1. Select in the editor Current situation
  2. Hover over 'Geo Import' from the ribbon bar
  3. Select 'Show Project Sources'
The project sources panel shows the used Sources in the project, such as Geo data sets, as well as data imported by users. This panel also provides dataset explanations and allows users to rename or remove WFS or CSW connections.
The sources are divided into four categories:
  • Catalog Services
This section displays the default CSW connections from the Geo Data Wizard. Also CSW connections added by a user are listed here.
When a user adds a CSW connection, the connection can be removed from the list or it is possible to edit the URL, name and other information in the panel on the right.
  • Default Sources
  • User Sources
  • Web Services
This section displays the default WFS connections from the Geo Data Wizard. Also WFS connections added by a user are listed here.
When a user adds a WFS connection, the connection can be removed from the list or it is possible to edit the URL, name and other information in the panel on the right.
