How to load grid values from a GeoShare WMS
When creating and using a Template Project, the inclusion of additional data is a common requirement. Vector-based data can be imported manually or automatically through various methods. For grid data, the ideal route is connecting to an external WCS. However, it is possible to upload large grid datasets in the form of GeoTIFFs to the GeoShare and have their data included automatically in Projects generated based on a properly configured Template Project. Calculations based on this data can then be run automatically and without significant manual intervention.
These instructions assume the desired GeoTIFFs are already uploaded to the GeoShare, ideally in a designated directory.
How to load grid values from a GeoShare WMS:
- Open the GeoShare, and navigate to the directory with the desired GeoTIFF file(s).
- Opt to create a Viewer, and add the desired GeoTIFF(s) to it.
- Click on the "edit" option of the newly created Viewer, and open the "WMS Link". This opens a page in the web browser.
- In the web browser, copy the URL of the WMS to the clipboard. This URL will be required later.
- Ensure the intended Project is open in the Editor.
- Add a WMS Overlay
- Click on Configuration Wizard in the WMS Overlay detail panel.
- Continue to the Import Method step, and select Import a web Map Service.
- Opt to add a new web Map Service.
- Enter a name for the WMS indicative of the content of the data.
- Paste the copied URL in the Website URL field.
- Click on the Add button to verify and add a new WMS Source.
- In the Import from Layer step, select the layer matching the desired GeoTIFF.
- In the Overlays step, select the result type of the WMS Overlay to Grid Value (float32).
- Combine multiple GeoTIFFs into one Grid Overlay by loading them via a multi-layer WMS Overlay, then merging timeframes with a Combo Overlay.
- If the WMS should use nearest neighbor for rasterizing and generating the resulting image, add the query parameter STYLES=NEAREST to the WMS Source URL:
share.tygron.com/share/mydomain/myfolder/myviewer/wms.viewer?token=TOKEN&STYLES=NEAREST
- How to combine GeoTIFFs on the Geoshare into a single Grid Overlay using WMS Overlays
- How to convert specific values from a Float32 result WMS Overlay to NO_DATA
