How to initialize a groundwater prequel
Initial configurations for the complete groundwater model of the Water Overlay often do not represent the state 'at rest'. Consequently, groundwater typically flows toward a more stable configuration during the simulation's initial period. For example, an initial groundwater dataset may have a consistent groundwater level defined for a large plot of land, while the more natural situation may be that the water follows a curve due to the way water flows into and out of the ground.
In short simulations, groundwater may not reach a natural state before the main event or simulation end. To compensate, run a stationary calculation first to allow the groundwater to settle, then use this stable result as the initial state.
This can also be achieved in a dynamic setup in which the calculation for initialization is set up as a "prequel", an explicit precursor calculation to the actual simulation.
How to initialize a groundwater prequel:
  1. Add a Groundwater Overlay to initialize the groundwater level before the actual simulation.
  2. Ensure that the Groundwater Overlay has the groundwater mode set to "Complete".
  3. Ensure that the Groundwater Overlay has data for groundwater set, if one is available.
  4. Ensure that the Groundwater Overlay has a ground last value output.
  5. Configure the rainfall for the model to run stationary, for a period of multiple weeks.
  6. Recalculate the Groundwater Overlay.
  7. Add a second Groundwater Overlay, which will use the first Groundwater Overlay's results as input.
  8. Open the second Groundwater Overlay's Water Overlay configuration wizard, and proceed to the groundwater step.
  9. Select the option "Select a Groundwater Depth Grid Overlay".
  10. Select the first Groundwater Overlay as prequel.
