How to edit general network settings
This how-to describes how to edit general Net Settings. These are settings that impact all Net Types.
The right panel for general network settings for all networks.
Editor → Current Situation (Ribbon tab) → Networks (Ribbon bar) → General Settings
Default Connected Load Fraction
The default fraction of demand from connected loads that is counted for a cluster.
Require approval Network Constructor
Whether the owner of the network has to approve the action of connecting a cluster.
Directly accept first connection request
Whether the first act of connecting a cluster can be done without approval.
Show Cluster Models
Whether clusters should be made visible in the 3D Visualization.
Show Load To Node Lines
Whether there should be indicative lines showing which loads are related to which nodes.
Calculation Model
How the flow of resources is calculated.
