How to add a Template Panel
The left panel for panels in the editor.
Template Panels allow similar Panels to be easily and automatically created. To use a Template Panel, it must first be added to the Project.
Editor → Current Situation (Ribbon tab) → Panels (Ribbon bar)
How to add a Template Panel:
  1. Open the list of Panels.
  2. At the bottom of the left panel, select the desired type of Template Panel.
  3. Click on "Add Panel".
  4. The Template Panel is now added.
  • Adding a Template Panel does not yet result in a Panel which is accessible to the end-user. It must be applied first to create accessible instances.
API Endpoints
