Client Event
Revision as of 09:55, 18 November 2026 by Server@tygron.com (talk | contribs)
Client events are not communicated to the Tygron Engine and are usually a graphical effect for the stakeholder who triggered the event. Examples of this include the flashing of an action menu or an indicator to draw the user's attention, or the visualization of a weather effect, such as a rain storm.
How do Client Events relate to the Tygron Platform
Client Events can be used on multiple locations in the Tygron Platform; as part of a measure, as part of a larger Event Bundles in an Action Menu, or during a cinematic sequence. Client Events do not communicate with the server, but trigger a reaction locally on the user's system.
See also: Measures, Actions & Cinematics
List of Client Event types
Below is a list describing the available Client Event Types:
ACTIVATE_WEATHER Activate the selected weather type on the client system
ACTIVATE_VIDEO Activate video on the client system with selected video loaded
BLINK_INDICATOR Make the selected indicator icon on the client system blink, to attract the user's attention
BLINK_OVERLAY Make the selected overlay icon on the client system blink, to attract the user's attention
BLINK_CATEGORY Make the selected action menu category icon on the client system blink, to attract the user's attention
BLINK_STOP_ALL Cancel all the blinking of icons
CHANGE_ZONE_PERMIT Change the zoning permit for the selected zone ID
FEEDBACK_PANEL_SHOW_TEXT Display the entered text on a small panel on the bottom of the main project view
FEEDBACK_PANEL_HIDE_TEXT Remove the feedback panel from the main project view
FORCE_ACTIVATE_VIDEO Force a selected video to play on the client system
RANDOM_ACTIVATE_POPUP_PERCENTAGE Respond to a popup with a given chance with the first answer of that popup
SELECT_HOTSPOT Activate the selected popup panel
SET_VISUALIZATION_SPEED Adjust the visualization speed of environmental animations (e.g., movement of clouds) with a factor larger than 0
SHOW_BROWSER_MAP Open a new window containing the ArcGIS Online map of the project area
SHOW_OVERLAY Activate the selected overlay
SHOW_PANEL Activate the selected panel
STOP_WEATHER Halt any previously activated weather
TILE_ATTENTION Gives visual attention for a given point and amount of seconds
Adding Client Events to a project
As mentioned above, events can be added to a project element on multiple occasions and locations. Please refer to the main articles relating to these elements for more information about the specific steps to take.
Generally, select the element (e.g., measures, levels) in the left panel, then add events via the right panel. Click the Add Event button at the bottom of the right panel to create a default NO_DEF event. Selecting an Event on the list and using the 'Remove Event' button deletes the event from the list.
Selecting an event opens the bottom panel to choose the event type. Confirm with Commit or clear with Cancel.
How to add events to a project element:
  1. Select Project Element to have events added to
  2. Select the Event option on the left panel
  3. Select 'Add event' on the bottom of the right panel
  4. Select the newly added event on the right panel
  5. Select the desired client event from the bottom panel
  6. Confirm the selection with the 'Commit' button (or use the 'Cancel' button to clear the selection
Event bundle bottom panel with 'Commit' and 'Cancel' buttons
Changing the properties of a Client Event in a project
The properties of events can be edited on the bottom panel (see image above). On this panel a linked ID of a measure or cinematic can be linked to an event for instance. Any changes made need to be confirmed first with the 'Commit' button, or canceled with the 'Cancel' button.
