How to select a GeoTIFF for a GeoTIFF Overlay
Revision as of 09:53, 18 November 2026 by Server@tygron.com (talk | contribs)
GeoTIFF Selection Panel.
A GeoTIFF Overlay can be used to visualize the grid data of one or more GeoTIFFs.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The GeoTiff Overlay (Left panel)
How to select one or more GeoTIFFs for a GeoTIFF Overlay:
  1. Select the GeoTIFF Overlay to configure.
  2. In the right panel, find the "GeoTIFF(s)" entry, and click on "configure". Alternatively, select the "TIFFs" tab.
  3. At the bottom of the right panel, select "Add". This will open the GeoTIFF Selection Panel.
  4. If the desired GeoTIFF is not yet part of the Project's Assets, opt to add a new file at the bottom of the GeoTIFF Selection Panel.
  5. When the desired GeoTIFF is listed, select it in the list of GeoTIFFs.
  6. If multiple GeoTIFFs are desired, select all desired GeoTIFFs.
  7. With the desired GeoTIFFs selected, click on "Select". This will close the GeoTIFF Selection Panel.
  8. The GeoTIFFs are now used as input for your GeoTIFF Overlay.
  • Multiple GeoTIFFs can be selected by using shift and ctrl.
  • GeoTIFFs can be reordered by selecting them in the left panel, and using the "Move Up" and "Move Down" options to change their order.
