How to edit the Camera Position
Revision as of 09:53, 18 November 2026 by Server@tygron.com (talk | contribs)
The buttons in camera editing mode.
When the "Edit Camera Position" button is selected, you enter camera editing mode. This mode allows you to edit the camera location and orientation for the selected Key Point. The "Edit Camera Position" button is replaced by options in the right panel to store the camera position. In the 3D Visualization, an object will be visible to help orient the camera.
Moving the Camera
This object indicates where the camera is currently aimed at.
While editing the camera position for a cinematic, you have more exact control over the camera. These controls differ from normal movement and can be operated via mouse, keyboard, or both.
How to Editing the camera position with your mouse:
  1. To start moving the camera, press both mouse buttons and drag your mouse
  2. To move the camera, use the left mouse button.
  3. To move the camera up and down, use both mouse buttons at the same time.
  4. To change the direction the camera is pointed at, use the right mouse button.
  5. To rotate the camera around its axis, scroll up or down with the scroll wheel.
How to Editing the camera position with your keyboard:
  1. To navigate you can use the arrow buttons on your keyboard.
  2. The left and right arrow keys rotate the camera around the target object, allowing for a full 360-degree view.
  3. Use the up and down arrow keys to move the camera up or down based on the focus point.
Store Camera Position
The button to store camera position.
When the camera is in the position you want for this Key Point, you can press "Store Camera Position" to store the current location and orientation of the camera for this Key Point.
Stop Editing Camera Position
The button to stop editing the camera position.
When you are done editing the camera position for this Key Point, you can press "Stop Editing Camera Position" to leave the camera editing mode. The camera will reset to the camera position set for this Key Point. If you store your current camera position right before stopping camera editing mode, you will not see the camera move.
