How to (de)activate a Neighborhood per Scenario
Revision as of 09:52, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Multi Scenario (Ribbon tab) → Scenario (Ribbon bar) → The Scenario to edit (Left panel)
How to (de)activate Neighborhoods per scenario:
  1. Load or create a project with existing Neighborhoods in the editor
  2. From the Ribbon of the editor, select Multi-Scenario > Scenarios
  3. On the Left Panel of the Editor, select (expand) the scenario where neighborhoods need to be (de)activated
  4. At the bottom of the expanded options for the selected level, select 'Events'.
  5. Click Add in the Right Panel to create a new server event.
  6. Select the event that has been added in the list above.
  7. In the Bottom Panel, select the LogicEventType NEIGHBORHOOD_SET_ATTRIBUTE.
  8. For the selected event, select the neighborhood that you want to (de)activate.
  9. Fill in the attribute ACTIVE for the Valid attribute name.
  10. Use the Attribute value 0 to deactivate and 1 to activate the neighborhood.
