Api session event editor netfunction
Revision as of 10:26, 13 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetfunction/
API Endpoints for Net Function editing.
Name Description
add Add a Net Function with a particular Net Type
append_attribute Appended to existing Net Function numeric Attribute value
import Import Net Functions by providing names, Net Types and Attributes with accompanying values
remove Remove existing Net Function
remove_attribute Remove numeric Attribute from Net Function
set_attribute Set Net Function numeric Attribute value
set_attributes Set multiple Net Function numeric Attribute values
set_name Set the name of a Net Function
Additional API Endpoints:
Name Description
remove_all_attributes Remove all Attributes of a Net Function
set_type Set the Net Type of a Net Function
