Api session event editor netfunction set name
API Endpoint: api/session/event/editornetfunction/set_name/
Description: Set the name of a Net Function
| 0 | REQUIRED | (NET_FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) | Net Functions | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Names |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetfunction/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetfunction/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name 1", "Name 2", "Name 3" ] ]'JavaScript example POST
body: '[ 1, "Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editornetfunction/set_name/", options)
